Using Siebel Tools > Using Siebel Tools > Using Menus and Running Queries >
Using a Right-Click Menu
A right-click menu is a type of context sensitive menu that Siebel Tools displays if you right-click an object or an element. It allows you to do the following:
- Create, copy, or delete a record.
- Undo modifications you make to a record.
- Open the Applet Layout Editor or the View Layout Editor from the Object List Editor. You right-click an applet or a view, and then choose Edit Web Layout.
- View and edit a Web template. You right-click a Web template in the Object List Editor, and then choose View Web Layout.
- Display the name and status of a toolbar. You right-click any toolbar. You can also modify how Siebel Tools displays a toolbar.
- Check out or lock an object.
- Add an object to an archive.
- Access wizards.
