Using Siebel Tools > Using Siebel Tools > Using Windows, Wizards, and Toolbars >
Using the Web Template Explorer Window
The Web Template Explorer window is a window that displays the HTML code of a Siebel Web Template (.swt) file. To Use the Web Template Explorer Window
- In Siebel Tools, choose the View menu, Windows, and then click Web Templates Window.
To filter the templates, you can use the Web Template drop-down list in the Web Template Explorer.
- In the Web Templates window, choose the Web template you must modify.
Siebel Tools displays the HTML code for the .swt file in a separate window.
- To edit the HTML code, right-click the window that displays this code, and then choose Edit Template.
