Using Siebel Tools > Using Siebel Tools > Using Windows, Wizards, and Toolbars > Displaying, Docking, and Stacking WindowsThis topic describes how to display, dock, and stack windows. Displaying a WindowYou can display or hide a window.
Docking a WindowYou can dock a window in a corner of the main window.
Displaying a Window as a TabYou can display a docked window, including the Object Explorer, as a tab. You can open, close, or dock a tabbed window.
Stacking WindowsYou can stack windows on top of each other if they are floating.
Resetting WindowsYou can reset windows to the display that Siebel Tools uses immediately after you first install it. |
| Using Siebel Tools | Copyright © 2013, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
