Using Siebel Tools > Using Siebel Tools > Process of Setting Up the Development Environment >
Setting Database Options
This task is a step in Process of Setting Up the Development Environment. This topic describes how to set database options. To set database options
- In Siebel Tools, choose the View menu, and then click Options.
- In the Development Tools Options dialog box, click the Database tab.
- Set the options. Use the information in the following table, and then click OK.
Developing for Deployment on DB2 for zSeries |
For more information, see Implementing Siebel Business Applications on DB2 for z/OS. |
Limit Schema Object Names to 18 Characters |
Allow to Create Column of Type 'Character' Being Greater Than 1 |
Allows columns of type CHAR to be greater than one character in length. If a column is a CHAR type column, and if the data that this column stores is variable in length, then Siebel CRM pads the data with empty spaces in the database. |
