| Oracle® Beehive Installation Guide Release 1 (1.5) for Microsoft Windows (32-Bit) Part Number E14831-05 |
View PDF |
These steps describe how to upgrade Oracle Collaboration Coexistence Gateway from version 1.4.3 to version 1.5:
Start the Oracle Beehive Install Wizard.
In the Select Product Type screen, select Oracle Beehive Collaboration Coexistence Gateway.
Select one of the following options:
Oracle Coexistence Connector for Microsoft Exchange Server: Select this option if you are starting the Oracle Collaboration Coexistence Gateway upgrade process. If Oracle Change Notification Service is installed in the same machine as Oracle Coexistence Connector, then this option will also upgrade Oracle Change Notification Service.
Oracle Change Notification Service for Microsoft Exchange Server: You will only select this option if you have upgraded Oracle Coexistence Connector, and the Oracle Change Notification Service to be upgraded is installed in a different machine than Oracle Coexistence Connector.
You will see the following sequence of screens:
Notes:
Upgrade all Oracle Coexistence Connector for Microsoft Exchange Server instances installed in the current Microsoft Exchange Server environment before upgrading any Oracle Change Notification Service for Microsoft Exchange Server instances.Ensure the following before proceeding with upgrading Oracle Collaboration Coexistence Gateway:
Ensure that there is only one window session (desktop) is present. Close all other window sessions. Many window sessions can be opened with Windows Remote Desktop or Virtual Network Computing (VNC) applications.
Ensure that you have closed all Windows Explorer windows, unnecessary applications, and command prompts. These may interfere with the upgrade process, especially if Windows Explorer or a command prompt is pointing to the directory <Oracle home>\j2ee.
If the Oracle Beehive Wizard detects Oracle Coexistence Connector installed on the machine from which you started the wizard, the following screens will appear:
If the installer detected that Oracle Coexistence Connector version 1.4.3 is installed in your machine, specify Yes to upgrade it to version 1.5.
If you specify No, the Install Wizard will proceed to install Oracle Coexistence Connector version 1.5 in a new Oracle home.
Select from the drop down box the complete path of the Oracle Beehive product you want to upgrade.
The drop down box will only contain Oracle Beehive home paths with the following characteristics:
Contains Oracle Coexistence Connector version 1.4.3
Is registered in the central Oracle Universal Installer inventory of the machine from which you started the Install Wizard.
Shut down the Oracle Coexistence Connector instance that you are upgrading. Select the Manually Verified check box once you have shut down Oracle Coexistence Connector.
Refer to "Stopping Oracle Connector for Exchange" in "Configuring and Managing Oracle Collaboration Coexistence Gateway" in Oracle Beehive Administrator's Guide for more information.
The Upgrade Summary screen presents a summary of the options you have specified so far:
Space Requirements: The disk space required to upgrade the product. The space requirement appears in a different color if the disk space available is less than what is required.
Notes:
The space requirements shown on this screen do not include the space required in the target database.The space requirements shown on this screen also might differ slightly from the actual space the component occupies on the installation disk. This is because of the differences in the disk configurations. For example, the space required on one hard drive might differ from the space required on another hard drive that uses different block size or that is managed by a different file system.
Inventory Location: The location of the oraInventory directory where all the installation information about your product will be stored.
Product: The name of the product you are upgrading, Oracle Coexistence Connector
Interview Details: The details of your inputs for the other screens, such as:
Home Details: The location of the Oracle home that you are upgrading.
When you have reviewed your inputs, click Upgrade to continue.
Use this screen to monitor the upgrade process. Click Show Details to see the details in the description box that appears.
This screen displays the configuration assistants that the Oracle Beehive Install Wizard runs to upgrade Oracle Coexistence Connector.
This screen indicates if the upgrade of Oracle Coexistence Connector is successful.
If the Oracle Beehive Wizard detects Oracle Change Notification Service installed on the machine from which you started the wizard, the following screens will appear:
If the installer detected that Oracle Change Notification Service version 1.4.3 is installed in your machine, specify Yes to upgrade it to version 1.5.
If you specify No, the Install Wizard will proceed to install Oracle Change Notification Service version 1.5 in a new Oracle home.
Contains Oracle Change Notification Service version 1.4.3
Shut down the Oracle Change Notification Service instance that you are upgrading. Select the Manually Verified check box once you have shut down Oracle Change Notification Service.
Refer to "Stopping Oracle Change Notification Service for Exchange" in "Configuring and Managing Oracle Collaboration Coexistence Gateway" in Oracle Beehive Administrator's Guide for more information.
Notes:
Product: The name of the product you are upgrading, Oracle Change Notification Service
This screen displays the configuration assistants that the Oracle Beehive Install Wizard runs to upgrade Oracle Change Notification Service.
This screen indicates if the upgrade of Oracle Collaboration Coexistence Gateway is successful.
