This preface discusses:
Application fundamentals.
Deferred processing.
Common elements.
Note. This PeopleBook documents only page elements that require additional explanation. If a page element is not documented with the process or task in which it is used, then it either requires no additional explanation or is documented with the common elements for the section, chapter, or PeopleBook.
This PeopleBook refers to these products:
PeopleSoft Enterprise Cash Management.
PeopleSoft Enterprise Deal Management.
PeopleSoft Enterprise Risk Management.
PeopleSoft Enterprise Billing.
PeopleSoft Enterprise General Ledger.
PeopleSoft Enterprise Payables.
PeopleSoft Enterprise Purchasing.
PeopleSoft Enterprise Receivables.
PeopleSoft EnterpriseOne General Accounting.
PeopleSoft Banks Setup and Processing PeopleBookprovides implementation and processing information for PeopleSoft Banks. Additional essential information describing the setup and design of your system resides in companion documentation. The companion documentation consists of important topics that apply to many or all PeopleSoft applications across the Financials, Enterprise Service Automation, and Supply Chain Management product lines. You should be familiar with the contents of these PeopleBooks.
These PeopleBooks complement the Banks Setup and Processing PeopleBook:
PeopleSoft Enterprise Applications Fundamentals 9.1 PeopleBook.
PeopleSoft Enterprise Global Options and Reports 9.1 PeopleBook.
Several pages in this PeopleBook operate in deferred processing mode. The system does not update or validate most fields on these pages until you save the page or refresh it by clicking a button, link, or tab. This delayed processing has various implications for the field values on the page; for example, if a field contains a default value, any value you enter before the system updates the page overrides the default. Another implication is that the system updates quantity balances or totals only when you save or otherwise refresh the page.
See Also
PeopleTools PeopleBook: PeopleSoft Application Designer
A companion PeopleBook called PeopleBooks and the PeopleSoft Online Library contains general information, including:
Understanding the PeopleSoft online library and related documentation.
How to send PeopleSoft documentation comments and suggestions to Oracle.
How to access hosted PeopleBooks, downloadable HTML PeopleBooks, and downloadable PDF PeopleBooks as well as documentation updates.
Understanding PeopleBook structure.
Typographical conventions and visual cues used in PeopleBooks.
ISO country codes and currency codes.
PeopleBooks that are common across multiple applications.
Common elements used in PeopleBooks.
Navigating the PeopleBooks interface and searching the PeopleSoft online library.
Displaying and printing screen shots and graphics in PeopleBooks.
How to manage the locally installed PeopleSoft online library, including web site folders.
Understanding documentation integration and how to integrate customized documentation into the library.
Application abbreviations found in application fields.
You can find PeopleBooks and the PeopleSoft Online Library in the online PeopleBooks Library for your PeopleTools release.
Account |
ChartField that identifies the nature of a transaction for corporate accounts. |
Affiliate |
ChartField that is used to map transactions between business units when you use a single interunit account. |
Alt Acct (alternate account) |
ChartField that identifies the nature of a transaction for statutory accounts. This field appears only if you enable the Alternate Account option for your organization and for the general ledger business unit. |
Attachment |
Click this link to add, delete, and view attachments. When adding large attachments, you should save the transaction before adding the attachment. |
Bank Account |
Code that you define to identify a bank account on pages and in running processes and reports, such as CHCK (checking). |
Bank Account # (bank account number) or Account # (account number) |
Number or code that identifies a bank account, which the bank assigns. |
Bank or Bank Code |
Code that you define to identify a bank on pages and in running processes and reports. |
Bank ID |
Code that identifies a bank that is assigned by a bank regulatory agency. |
Branch or Branch Name |
Code that you define to identify a bank branch on pages and in running processes and reports. |
Branch ID |
Unique identifier for a branch of a bank, which you get from the bank. |
Budget Ref (budget reference) |
ChartField that identifies unique budgets when individual budgets share budget keys and overlapping budget periods. |
Class |
ChartField that identifies a particular appropriation when you combine it with a fund, department ID, program code, and budget reference. |
Counterparty |
A counterparty is a bank that has a trading relationship with your organization. |
Currency |
Code that identifies the type of currency for an amount, such as USD for US dollar or EUR for euro. |
Dept (department) |
ChartField that indicates who is responsible for or affected by the transaction. |
Description |
Free-form text field with a maximum limit of 256 characters. |
Effective Date |
Date on which a table row becomes effective; the date that an action begins. For example, if you want to close out a ledger on June 30, the effective date for the ledger closing would be July 1. This date also determines when you can view and change the information. Pages or panels and batch processes that use the information use the current row. |
Fund |
ChartField that represents structural units for education and government accounting. Can also represent a divisional breakdown in your organization. |
Fund Affiliate |
ChartField used to correlate transactions between funds when using a singe intraunit account. |
Reference |
Reference number for a bank transaction. |
Oper Unit (operating unit) |
ChartField used to identify a location, such as a distribution warehouse or sales center. |
Process Frequency |
Designates the appropriate frequency in the Process Frequency group box: Once: Executes the request the next time the batch process runs. After the batch process runs, the process frequency is automatically set to Don't Run. Always: Executes the request every time the batch process runs. Don't Run: Ignores the request when the batch process runs. |
Process Monitor |
This link takes you to the Process List page, where you can view the status of submitted process requests. |
Product |
ChartField that captures additional information that is useful for profitability and cash flow analysis by product sold or manufactured. |
Program |
ChartField that identifies groups of related activities, cost centers, revenue centers, responsibility centers, and academic programs. Tracks revenue and expenditures for programs. |
Project |
ChartField that captures information for project/grants accounting. |
Report Manager |
This link takes you to the Report List page, where you can view report content, check the status of a report, and see content detail messages (which display a description of the report and the distribution list). |
Run |
This button takes you to the Process Scheduler request page, where you can specify the location where a process or job runs and the process output format. |
Run Control ID |
A code that identifies the run parameters for a report or process. |
SetID |
A code that represents information stored in a set of control table or TableSets. A TableSet is a group of tables (records) necessary to define your company's structure and processing options. |
Short Description |
Free-form text field with a maximum limit of 15 characters. |
Status |
Indicates whether a row in a table is active or inactive. You cannot display inactive rows on transaction pages or use them for running batch processes. Inactivate rather than delete data that you no longer use in order to maintain an audit trail. |
Stmt ID (statement ID) |
The statement number that is generated by the PeopleSoft application. |
Transaction Amount |
Amount of a statement transaction. |
Unit |
Business unit for an item. |
See Also
PeopleTools PeopleBook: Using PeopleSoft Applications
