This chapter contains the following topics:
For JD Edwards EnterpriseOne releases Xe through 8.12, you must add base currency conversion programs to the scheduler before you set up conversion plans and run the base currency conversion. The scheduler should contain a list of all of the conversion programs to be run at your site. You must add specific conversion programs for the systems that you use so that the scheduler list is complete and accurate for your release.
The conversion programs that must be added are described in tables in this section, by release.
For release Xe and the systems that you use, add the appropriate conversion programs from this list:
| Table Number | Conversion Program |
| F1403 | R891403E
Also converts F1406 |
| F1404 | R891404E
Also converts F14041 |
| F15012 | R8915012BE |
| F15013 | R8915013BE |
| F15014 | R8915014BE |
| F15015 | R8915015BE |
| F15016 | R8915016BE |
| F1502 | R891502BE |
| F1502WB | R891502WBE |
| F1502 | R891502BE |
| F1505 | R891505BE |
| F1507 | R891507E |
| F1511 | R891511BE |
| F1511H | R891511HBE |
| F1513 | R891513BE |
| F1532B | R891532BE |
| F1538 | R891538BE |
| F1540 | R891540BE |
| F15410 | R8915410E |
| F1541B | R891541BE |
| F1543B | R891543BE |
| F1565 | R891565E |
| F159071 | R89159071E |
| F1755 | R891755E |
| F3908 | R893908E |
| F3910 | R893910E |
| F39061 | R8939061E |
| F390619 | R89390619E |
| F39062 | R8939062E |
| F39063 | R8939063E |
| F390639 | R89390639E |
| F39064 | R8939064E |
| F390649 | R89390649E |
| F39120W | R8939120WE |
| F39121W | R8939121WE |
| F44H101 | R8944H101E |
| F44H201 | R8944H201E |
| F44H301 | R8944H301E |
| F44H401 | R8944H401E |
| F44H4101 | R8944H410E |
| F44H501 | R8944H501E |
| F44H511 | R8944H511E |
| F44H591 | R8944H591E |
| F44H603 | R8944H603E |
| F44H611 | R8944H611E |
| F44H711 | R8944H711E |
| F44H711P | R8944H711P |
| F44H0929 | R8944H929E |
| F48S912 | R8948S912E |
| F49633 | R894941E |
| F49634 | R894915E |
For release 8.0 and the systems that you use, add the appropriate conversion programs from this list:
| F1403 | R891403E
| F1404 | R891404E
| F1502 | R891502BE |
| F1505 | R891505BE |
| F1507 | R891507E |
| F1511 | R891511BE |
| F1513 | R891513BE |
| F1538 | R891538BE |
| F1540 | R891540BE |
| F1541BW | R891541BWE |
| F1542 | R891542E |
| F1565 | R891565E |
| F15L100 | R8915L100E |
| F15L101 | R8915L101E |
| F15L102 | R8915L102E
Also converts F15L112 |
| F15L105 | R8915L105E |
| F15L108 | R8915L108E
Also converts F15L118 |
| F15L109 | R8915L109E |
| F15L113 | R8915L113E |
| F15L114 | R8915L114E |
| F15L301 | R8915L301E |
| F15L38 | R8915L38E |
| F1755 | R891755E |
| F3908 | R893908E |
| F3910 | R893910E |
| F39061 | R8939061 |
| F49633 | R894941E |
| F49634 | R894915E |
| F5280 | R895280E |
For release 8.9 and the systems that you use, add the appropriate conversion programs from this list:
| F1403 | R891403E
| F1404 | R891404E
| F1502 | R891502BE |
| F1505 | R891505BE |
| F1507 | R891507E |
| F1511 | R891511BE |
| F1513 | R891513BE |
| F1538 | R891538BE |
| F1540 | R891540BE |
| F1542 | R891542E |
| F1565 | R891565E |
| F1755 | R891755E |
| F3908 | R893908E |
| F3910 | R893910E |
| F49633 | R894941E |
| F49634 | R894915E |
| F5280 | R895280E |
For release 8.10 and the systems that you use, add the appropriate conversion programs from this list:
| F1383 | R891383E |
| F1403 | R891403E
| F1404 | R891404E
| F1502 | R891502BE |
| F1505 | R891505BE |
| F1507 | R891507E |
| F1511 | R891511BE |
| F1513 | R891513BE |
| F1538 | R891538BE |
| F1540 | R891540BE |
| F1542 | R891542E |
| F1565 | R891565E |
| F15L110 | R8915L110E
Also converts F15L111 |
| F15L302 | R8915L302E |
| F1755 | R891755E |
| F3908 | R893908E |
| F3910 | R893910E |
| F49633 | R894941E |
| F49634 | R894915E |
| F5280 | R895280E |
For release 8.11 and the systems that you use, add the appropriate conversion programs from this list:
| F1383 | R891383E |
| F1403 | R891403E
| F1404 | R891404E
| F1502 | R891502BE |
| F1505 | R891505BE |
| F1507 | R891507E |
| F1511 | R891511BE |
| F1513 | R891513BE |
| F1538 | R891538BE |
| F1540 | R891540BE |
| F1542 | R891542E |
| F1565 | R891565E |
| F1755 | R891755E |
| FF31111 | R89F31111E |
| FF31113 | R89F31113E |
| FF31200 | R89F31200E |
| FF30L002 | R89F30L02E |
| F3908 | R893908E |
| F3910 | R893910E |
| F4316 | R894301E
Also converts F4301, F4311, F4311T, F4316T, F4317 |
| F43E01 | R8943E01E
Also converts F43E11, F43E16 |
| F49633 | R894941E |
| F5280 | R895280E |
| F49634 | R894915E |
| F76V4025 | R8976V3E |
| F76V4030 | R8976V4E |
For release 8.11 SP1 and the systems that you use, add the appropriate conversion programs from this list:
| F1383 | R891383E |
| F1403 | R891403E
| F1404 | R891404E
| F1502 | R891502BE |
| F1505 | R891505BE |
| F1507 | R891507E |
| F1511 | R891511BE |
| F1513 | R891513BE |
| F1538 | R891538BE |
| F1540 | R891540BE |
| F1542 | R891542E |
| F1565 | R891565E |
| F1755 | R891755E |
| F3908 | R893908E |
| F3910 | R893910E |
| F4316 | R894301E
| F43E01 | R8943E01E
| F49633 | R894941E |
| F49634 | R894915E |
| F5280 | R895280E |
For release 8.12 and the systems that you use, add the appropriate conversion programs from this list:
| F1383 | R891383E |
| F1403 | R891403E
| F1404 | R891404E
| F1502 | R891502BE |
| F1505 | R891505BE |
| F1507 | R891507E |
| F1511 | R891511BE |
| F1513 | R891513BE |
| F1538 | R891538BE |
| F1540 | R891540BE |
| F1542 | R891542E |
| F1565 | R891565E |
| F1755 | R891755E |
| F3908 | R893908E |
| F3910 | R893910E |
| F40G150 | R8940G150E |
| F4316 | R894301E
| F43E01 | R8943E01E
| F43Q10 | R8943Q10E |
| F43Q11 | R8943Q11E |
| F43Q20 | R8943Q20E |
| F43Q21 | R8943Q21E |
| F43Q40 | R8943Q40E |
| F43Q401 | R8943Q401E |
| F43Q41 | R8943Q41E
Also converts F43Q413 |
| F43Q411 | R8943Q411E |
| F43Q412 | R8943Q412E |
| F43Q51 | R8943Q51E |
| F49633 | R894941E |
| F49634 | R894915E |
| F5280 | R895280E |
For release 9.0 and the systems that you use, add the appropriate conversion programs from this list:
| F0010 | R890010E |
| F0018R | R890018RE |
| F0075 | R890075EB |
| F06116 | R8906116E |
| F0618 | R890618E |
| F0709 | R890709E |
| F0902B | R890902BE |
| F0902B | R890902E |
| F0911 | R890911E |
| F0911 | R890911EB
F0911 for Multi-Currency Intercompany Transactions |
| F0911 | R890911JX
Account Ledger Currency Conversion for JX Documents |
| F09E108 | R8909E108E |
| F09E150 | R8909E150E |
| F90CB020 | R890CB02IE
Also converts F90CB02I |
| F90CB02M | R890CB02ME |
| F1002 | R890CB02ME |
| F1383 | R891002E |
| F1403 | F891403E
| F1404 | R891404E
| F150122 | R89150122E |
| F1505 | R891505HEB |
| F15L100 | R89151001E |
| F15151 | R8915151EB |
| F15152 | R8915152EB |
| F15153 | R8915153E |
| F1525 | R891525BE |
| F1530 | R8915303E |
| F1531 | R891531EB |
| F1533 | R891533BEB |
| F1538B1 | R891538B1E |
| F1538B2 | R891538B2E |
| F1539A | R891539AE |
| F1539C | R891539CEB |
| F1539E | R891539EE |
| F1539FC | R891539FCE |
| F1539FL | R891539FLE |
| F1541B | R891541BWE |
| F1542 | R891542E |
| F15703 | R8915703EB |
| F15L102 | R8915L102E |
| F15L110 | R8915L110E |
| F1602 | R891602E |
| F1611 | R891611E |
| F1632 | R891632E |
| F1721 | R891721E |
| F20103 | R8920103EB |
| F20104 | R8920104EB |
| F20111 | R8920111EB |
| F31B211 | R8931B211E |
| F31B31C | R8931B31CE |
| F31B66 | R8931B66EB |
| F39061 | R8939061E
Valuation Period Currency Conversion |
| F39061 | R8939061EB
Valuation Period DUAL Currency Conversion |
| F39062 | R8939062E
Valuation Layers Currency Conversion |
| F39062 | R8939062EB
Valuation Layers DUAL Currency Conversion |
| F39063 | R8939063E
Period Additional Quantity Currency Conversion |
| F39063 | R8939063EB
Period Additional Quantity DUAL Currency Conversion |
| F390649 | R8939064E
Valuation Document Summary Currency Conversion |
| F390649 | R8939064EB
Valuation Document Summary DUAL Currency Conversion |
| F3908 | R893908E |
| F3910 | R893910E
G/L Adjustment Currency Conversion |
| F3910 | R893910EB
G/L Adjustment DUAL Currency Conversion |
| F390619 | R8939619EB |
| F390639 | R8939639EB |
| F390649 | R8939649EB |
| F4001Z | R894001ZE |
| F4001Z | R894001ZEB |
| F40344 | R8940344E |
| F40G02 | R8940G02EB |
| F40G032 | R8940G032E |
| F40G032 | R8940G03EB |
| F42004 | R8942004E |
| F42008 | R8942008E |
| F42019 | R8942019E |
| F42019 | R894201E |
| F42119 | R8942119E |
| F42119 | R894211E |
| F42140 | R8942140E |
| F42150 | R8942150E |
| F42160 | R8942160E |
| F4229 | R894229E |
| F43199 | R8943199E |
| F4332 | R894332E |
| F43C01 | R8943C01EB |
| F43C30 | R8943C30EB |
| F43E01, F43E11 and F43E16 | R8943E01E |
| F43E20 | R8943E20EB |
| F43Q401 | R8943Q40E |
| F43Q41 and F43Q413 | R8943Q41E |
| F43Q60E | R8943Q60E |
| F44H410 | R8944H410E |
| F45715 | R8945715E |
| F4575 | R894575E |
| F4576 | R894576E |
| F47016, F47017, F470161,and F470171 | R8947016E |
| F47021 and F47022 | R8947021E |
| F47026 | R8947026E |
| F47027 | R8947027E |
| F47031 and F47032 | R8947031E |
| F470371 | R8947037E |
| F47041, F470042, and F47044 | R8947041E |
| F47046 | R8947046E |
| F47047 | R8947047E |
| F47071 and F47072 | R8947071E |
| F47076 and F47077 | R8947076E |
| F47096 and F47097 | R8947096E |
| F47106 | R8947106E |
| F47107 | R8947107E |
| F47131 | R8947131E |
| F47132 | R8947132E |
| F47141 and F47142 | R8947141E |
| F47146 | R8947146E |
| F47147 | R8947147E |
| F4722 | R894722E |
| F48096 | R8948096E |
| F4861 | R894861E |
| F48S85 | R8948S85E |
| F48S912E | R8948S912E |
| F5280 | R895280E |
| F52G60 | R8952G60E |
| F76V4581 and F76V4583 | R8976V6E |
| F90CB060 | R8990CB06E |
For release 9.1 and the systems that you use, add the appropriate conversion programs from this list:
| F0010 | R890010E |
| F0075 | R890075EB |
| F0618 | R890618E |
| F0709 | R890709E |
| F0902B | R890902E |
| F0911 | R890911E |
| F0911 | R890911EB
| F0911 | R890911JX
| F1383 | R891002E |
| F1403 | F891403E
| F1404 | R891404E
| F1525 | R891525BE |
| F1530 | R8915303E |
| F1531 | R891531EB |
| F1542 | R891542E |
| F1602 | R891602E |
| F1611 | R891611E |
| F1632 | R891632E |
| F1721 | R891721E |
| F39061 | R8939061E
| F39061 | R8939061EB
| F39062 | R8939062E
| F39062 | R8939062EB
| F39063 | R8939063E
| F39063 | R8939063EB
| F390649 | R8939064E
| F3908 | R893908E |
| F3910 | R893910E
| F3910 | R893910EB
| F42019 | R894201E |
| F42119 | R894211E |
| F4229 | R894229E |
| F4332 | R894332E |
| F4575 | R894575E |
| F4576 | R894576E |
| F4722 | R894722E |
| F4861 | R894861E |
| F5280 | R895280E |
| F15013B | R8915013BA |
For release 9.2 and the systems that you use, add the appropriate conversion programs from this list:
| F0010 | R890010E |
| F0075 | R890075EB |
| F0618 | R890618E |
| F0709 | R890709E |
| F0902B | R890902E |
| F0911 | R890911E |
| F0911 | R890911EB
| F0911 | R890911JX
| F1383 | R891002E |
| F1403 | F891403E
| F1404 | R891404E
| F1525 | R891525BE |
| F1530 | R8915303E |
| F1531 | R891531EB |
| F1542 | R891542E |
| F1602 | R891602E |
| F1611 | R891611E |
| F1632 | R891632E |
| F1721 | R891721E |
| F39061 | R8939061E
| F39061 | R8939061EB
| F39062 | R8939062E
| F39062 | R8939062EB
| F39063 | R8939063E
| F39063 | R8939063EB
| F390649 | R8939064E
| F3908 | R893908E |
| F3910 | R893910E
| F3910 | R893910EB
| F42019 | R894201E |
| F42119 | R894211E |
| F4229 | R894229E |
| F4332 | R894332E |
| F4575 | R894575E |
| F4576 | R894576E |
| F4722 | R894722E |
| F4861 | R894861E |
| F5280 | R895280E |
This section provides an overview of the scheduler and discusses how to add conversion programs to the scheduler.
The system loads records from the Table Conversion - JDE Scheduler table (F9843) into the Table Conversion Scheduler table (F98405) when you set up a conversion plan. The F9843 table, which contains the base currency conversion programs, is not completely accurate. To update the F9843 table for releases Xe through 8.12, you must add several conversion programs to the Table Conversion Scheduler program (P98430).
Important: Ensure that the conversion programs in the scheduler are current and accurate before you set up any conversion plans. |
| Form Name | FormID | Navigation | Usage |
| Work with Table Conversion Scheduler | W98430A | In the Windows environment, Advanced Operations (GH9611), Table Conversion Scheduler | Review a list of the conversion programs in the scheduler. |
| Scheduler Revisions | W98430B | On the Work with Table Conversion Scheduler form, click Add. | Add a conversion program to the scheduler. |
Access the Work with Table Conversion Scheduler form.
To update conversion programs in the scheduler:
On the Work with Table Conversion Scheduler form, enter 8 (euro conversion) in the Conversion Type field and click Find.
The system displays a list of base currency conversion programs.
Click Add.
For the remaining steps, refer to the list of scheduler conversion programs to add for your release.
On the Scheduler Revisions form, complete these fields:
Conversion Type. Enter 8 (euro conversion) to assign the base currency conversion type.
Table Name. Refer to the list from step 3.
From Release and To Release. Enter the same release number in these two fields.
Conversion Sequence Nbr. Enter the next available sequence number. To derive this number, locate the sequence number of the last conversion program in the scheduler and increment it by 1.
Dependent on Sequence.
Enter 0 (the default value) for this field for all conversion scheduler records except those for system 43Q tables (release 8.12 and above). Many of the system 43Q table conversion programs depend on the successful completion of previous conversion programs.
Specify these dependencies when you add scheduler records for system 43Q tables:
| Table | Dependency Sequence Number |
| F43Q11 | 0 (no dependency) |
| F43Q20 | Conversion sequence number for table F43Q11. |
| F43Q21 | Conversion sequence number for table F43Q20. |
| F43Q10 | Conversion sequence number for table F43Q21. |
| F43Q40 | 0 (no dependency) |
| F43Q401 | Conversion sequence number for table F43Q40. |
| F43Q41 | Conversion sequence number for table F43Q40. |
| F43Q411 | Conversion sequence number for table F43Q40. |
| F43Q412 | Conversion sequence number for table F43Q40. |
| F43Q51 | Conversion sequence number for table F43Q40. |
Conversion Program. Refer to the list from step 3.
Version. Enter XJDE0001 for all conversion scheduler records with the exception of the following. Enter ZJDE0001 for these conversion programs:
R8943Q10E
R8943Q11E
R8943Q20E
R8943Q21E
Click OK.
Repeat steps 2–5 for each conversion program identified in the list.
On the Work with Table Conversion Scheduler form, click Find to refresh the list of conversion programs.
Scroll down to the sequence numbers of the programs that you added to verify that they appear in the scheduler.
