Specify a number that identifies an engineer-to-order project in the system. You set up the project in the Add/Revise Project program (P31P011).
Specify a number that identifies a task in an engineer-to-order project in the system. You set up the project tasks in the Project Workbench program (P31P001).
Enter a value from user-defined code (UDC) 00/DT that identifies the type of document. This code also indicates the origin of the transaction. The system has reserved document type codes for vouchers, invoices, receipts, and time sheets, which create automatic offset entries during the post program. (These entries are not self-balancing when you originally enter them.) These document types are defined by the system and should not be changed:
P: Accounts Payable documents
R: Accounts Receivable documents
T: Payroll documents
I: Inventory documents
O: Purchase Order Processing documents
J: General Accounting/Joint Interest Billing documents
S: Sales Order Processing documents
ET: Engineer to Order
