This chapter contains the following topics:
The system must populate data in tables within the JD Edwards EnterpriseOne FMCC before you can run subsequent batch programs. This diagram shows the data flow of batch programs as organized into groupings based on data contingencies:
Figure 2-1 JD Edwards EnterpriseOne FMCC data process flow
The flowchart illustrates the sequential order in which the FMCC data load batch programs should be run.
