This chapter discusses these topics:
Section 4.1, "Business Unit and Company Import and Export Overview"
Section 4.2, "Using the Business Unit Import and Export Interface Components"
Section 4.3, "Using the Company Import and Export Interface Components"
Business interfaces are programs or software components that enable you to share data between JD Edwards EnterpriseOne and other external software systems. There are several business interface components that enable you to share business unit and company data between systems.
The following business interfaces have been created to enable data sharing of business unit data between JD Edwards EnterpriseOne and external software systems:
Business Unit Inbound Application program (P0006Z)
Use this program to manually enter records into the Business Unit Master Z File table (F0006Z2). You can also use this program to import business unit records into this table from a spreadsheet. Once records are added, you can use this program to update the records and add translation information for each record.
Business Unit Batch Inbound program (R0006ZI)
Use this program to transfer records from the F0006Z2 table into the live Business Unit Master table (F0006). Once data is transferred to this table, it is available for processing in the EnterpriseOne system.
Business Unit Inbound Purge (R0006ZP)
Use this program to delete data out of the F0006Z2 table after it has been processed.
See Also: For additional information about business unit setup, see Section 3.4, "Setting Up Business Units." |
The following business interfaces have been created to enable data sharing of company data between JD Edwards EnterpriseOne and external software systems:
Company Inbound Application program (P0010Z)
Use this program to manually enter records into the Company Master Z File table (F0010Z). You can also use this program to import company records into this table from a spreadsheet. Once records are added, you can use this program to update the records as needed.
Company Batch Inbound program (R0010ZI)
Use this program to transfer records from the F0010Z table into the live Company Master table (F0010). Once data is transferred to this table, it is available for processing in the EnterpriseOne system.
Company Inbound Purge (R0010ZP)
Use this program to delete data out of the F0110Z table after it has been processed.
Company Batch Outbound Program (R0010ZO)
This program extracts data from the Company Constants table (F0010), and writes the data into an XML file that can be consumed by an external software system.
See Also: For additional information about setting up company information, see Section 3.3, "Setting Up Companies." |
This section discusses these topics:
Section 4.2.1, "Forms Used to Access Business Unit Import and Export Interface Components"
Section 4.2.2, "Adding Business Unit Records Using the Business Unit Interface"
Section 4.2.4, "Setting Processing Options for the Business Unit Batch Inbound Program (R0006ZI)"
Section 4.2.5, "Running the Business Unit Batch Inbound Program (R0006ZI)"
Section 4.2.6, "Running the Business Unit Inbound Purge Program (R0006ZP)"
| Form Name | FormID | Navigation | Usage |
| Work With Business Unit - Inbound | W0006ZA | From the Business Interface Operations menu (G094116), select Business Unit Inbound Application | Review existing records, or access forms to add new busienss unit records. |
| Business Unit Revisions - Inbound | W0006ZB | From the Work With Business Unit - Inbound form, click Add. | Add records to the F0006Z2 table. |
| Business Unit Translations - Inbound | W0006ZC | From the Work With Business Unit - Inbound form, select a record, and then select Translations from the Row menu. | Add translation records to a business unit. |
Access the Work With Business Unit - Inbound form, and then click Add.
Figure 4-1 Business Unit Revision - Inbound
At a minimum, complete these required fields:
Action Code
Company
Business Unit
Description
Complete any addition fields, and then click OK to save your records. The records are then available in the F0006Z2, and can be processed by the Business Unit Batch Inbound Program (R0006ZI) to transfer the records into the F0006 table.
For additional information about business unit records, see Section 3.4, "Setting Up Business Units."
Access the Business Unit Translations - Inbound form.
Figure 4-2 Business Unit Translations Inbound
Action Code
Language Code
Description Compressed
For additional information about business unit translation records, see Section 3.4.1.2, "Business Unit Translation."
You use processing options to specify default processing information for a program.
From the Business Interface Operations menu (G094116), select Business Unit Batch Inbound.
From the Business Interface Operations menu (G094116), select Business Unit Inbound Purge.
Section 4.3.1, "Forms Used to Access Company Import and Export Interface Components"
Section 4.3.2, "Adding Company Records Using the Company Interface"
Section 4.3.3, "Running the Company Batch Inbound Program (R0010ZI)"
Section 4.3.4, "Running the Company Inbound Purge Program (R0010ZP)"
Section 4.3.5, "Running the Company Batch Outbound Program (R0010ZO)"
| Work With Company - Inbound | W0010ZA | From the Business Interface Operations menu (G094116), select Company Inbound Application | Review existing records, or access forms to add new company records. |
| Company Revisions - Inbound | W00010ZB | From the Work With Company - Inbound Form, click Add. | Add records to the F0010Z table. |
Access the Company Revisions - Inbound form.
At a minimum, complete these required fields on the :
Action Code
Company
For additional information about business unit records, see Section 3.3, "Setting Up Companies."
From the Business Interface Operations menu (G094116), select Company Batch Inbound.
From the Business Interface Operations menu (G094116), select Company Inbound Purge.
From the Business Interface Operations menu (G094116), select Company Batch Outbound.
