This chapter contains the following topics:
This section discusses how to set up manager approval of batches.
| Form Name | FormID | Navigation | Usage |
| System Setup | W0000A | Accounts Receivable Setup (G03B41), Accounts Receivable Constants
Accounts Payable Setup (G0441), Accounts Payable Constants General Accounting Setup (G0941), General Accounting Constants |
Select the system in which to set up management approval for batches. |
| Accounts Receivable Constants | W0000D | On the System Setup form, click Accounts Receivable Constants. On the Work with A/R Constants form, enter 00000 in the Company field. Click Find, and then click Select. | Set up management approval of batches for the Accounts Receivable system. |
| Accounts Payable Constants | W0000E | On the System Setup form, click Accounts Payable Constants. | Set up management approval of batches for the Accounts Payable system. |
| General Accounting Constants | W0000B | On the System Setup form, click General Accounting Constants. | Set up management approval of batches for the General Accounting system. |
Access the Accounts Receivable Constants, Accounts Receivable Constants, Accounts Payable Constants, or General Accounting Constants form.
Figure 2-1 General Accounting Constants form
You choose whether to have management approve each batch of transactions before the batch can be posted. You set up management approval for AR, AP, and GL, and not for specific companies.
Select this check box if manager approval is required for batches. The system assigns a Pending status to the batch and a manager must approve it before it can be posted.
If you do not select this check box, the system assigns an Approved status to the batch and the batch does not require that a manager approve it before it can be posted.
This section discusses how to set up batch security.
| Batch Approval / Post Security Constants | W00241A | G/L Advanced & Technical Operations (G0931), Batch Approval / Post Security Constants | Set up batch security by system and batch review security.
To print a list that shows the names of approved or restricted users for batch security, select Batch Security Rpt from the Report menu on the Batch Approval / Post Security Constants form. |
Access the Batch Approval / Post Security Constants form.
Figure 2-2 Batch Approval / Post Security Constants form
Select the corresponding check box to activate batch security editing in the JD Edwards EnterpriseOne General Accounting, JD Edwards EnterpriseOne Accounts Payable, or JD Edwards EnterpriseOne Accounts Receivable system. The system performs this editing when you approve and post batches for a particular system.
After you activate batch security editing, you must set up authority for secured users and approved users.
Select this check box to restrict unauthorized users from viewing batches other than their own using the General Journal Review program.
This section provides an overview of approved and secured users and discusses how to:
Set up approved users.
Set up secured users.
To have management approve each batch of transactions before the batch can be posted, you must set up two types of users:
Approved: Users that can approve and post batches for secured users.
Secured: Users that are restricted from approving and posting batches.
| Batch Approval / Post Security Constants | W00241A | G/L Advanced & Technical Operations (G0931), Batch Approval / Post Security Constants | Set up batch security by system and batch review security. |
| Approved by User | W00241F | On the Batch Approval / Post Security Constants form, select Approved by Users from the Form menu. On the Work With Approved by Users form, click Add. | Set up approved users. |
| Secured User | W00241J | On the Batch Approval / Post Security Constants form, select Secured Users from the Form menu. On the Work With Secured Users form, click Add. | Set up restricted users. |
Access the Approved by User form.
Enter the user ID of a person who is authorized to approve and post batches for a group of secured users. Secured users are restricted from approving and posting batches.
If the person has authority to approve and post all user batches, enter *ALL in the Secured User field instead of identifying each user individually.
Enter the address book number of a user who is restricted from approving and posting batches.
Enter the user ID of the person who is authorized to approve and post batches for the secured user in the Approved by User field.
This section provides an overview of workflow setup.
To approve batches or approve and post batches from the work center, you must first identify the approving managers in the appropriate workflow process. After each transaction batch is entered, the approver receives a workflow notification that the batch is ready for approval. Depending on the workflow process that you select, batches are either approved or approved and automatically submitted to post directly from the work center. Additionally, the employee who entered the batch receives notification that the batch was approved.
The system uses the workflow process in conjunction with the Batch Approval / Post Security Constants program (P00241) to determine who receives workflow messages. Because the system sends workflow messages only to workflow recipients, employees that you set up as approved users must also be set up as recipients in the workflow process.
Note: Employees who are set up as approved users can still approve batches from the appropriate batch review program. |
These workflow processes are available for approving batches:
JDEBCHAPR: Approve journal entry batches (batch type G).
JDEVBCHAPR: Approve voucher batches (batch type V).
Each workflow process has two versions:
Version 1: Approve batches only.
Version 2: Approve and post batches.
To set up the system to use workflow for approving and posting batches:
Activate either version 1 or 2 of the JDEBCHAPR or JDEVBCHAPR process.
Set up approving managers in recipient rules.
Set up the message queues that users can view using the Queue Security program (P01135).
