Specify whether the system considers the address book number as part of the hierarchy or if the system retrieves the address book number from the business unit associated with the forecast.
Enter a number that identifies an entry in Oracle's JD Edwards EnterpriseOne Address Book system, such as employee, applicant, participant, customer, supplier, tenant, or location.
Enter a date that indicates when a component part goes into effect on a bill of material or when a rate schedule is in effect.
Enter the forecasting method used to calculate the detail forecast for a specific item. Forecast type is also used to summarize forecasts in the system. For planning bills, the forecast type is used to create forecasts for components when you explode planning bills.
Enter the number that the system assigns to an item. The number can be in short, long, or third item number format.
