This chapter contains the following topics:
A commitment is the recognition of a future obligation. Each time you enter a subcontract order detail line, you can have the system track the amount that you are obligated to pay and apply it to a job or project.
For example, you might be working on a pavement resurfacing project. Each time you enter a purchase order for goods or a subcontract for services to complete the project, you can have the system create a commitment for the purchase order or subcontract amount.
In addition, you can roll over a commitment to the next fiscal year or have the commitments expire at year end.
For example, utilities, local governments, and municipalities normally have the authority to expend funds for one fiscal year. As a result, purchase orders and subcontracts with open balances are often canceled at the end of the fiscal year. Construction projects, however, can often span one or more years. In this case, the open balances of purchase orders and subcontracts are rolled forward to the new fiscal year.
A subcontract commitment is created when a subcontractor is contracted to provide services. The commitment is relieved when services are rendered and you initiate a progress payment.
A functional server program called Update Commitment Ledger (X00COM) is used to create and relieve commitments. The system uses the Update Commitment Ledger to create appropriate entries for subcontract system commitments.
You can create subcontract detail lines using the Subcontract Entry method in Purchase Orders (P4310).
When you create a subcontract detail line, the system verifies that the document type exists in user-defined code (UDC) 40/CT, verifies that the line type has an inventory interface of A or B, and automatically creates commitments and encumbrances.
If you create a subcontract from a requisition, you can track precommitments in addition to commitments. A precommitment is the recognition of a future obligation from which you can commit budget amounts based on that request. When you generate the subcontract from the requisition, the system relieves the precommitment and creates commitments for the resulting subcontract amounts.
Use the Commitment Relief constant in the Job Cost Constants program (P0026) to establish the criteria for the system to use to automatically relieve open commitments when you run the general ledger posting program for vouchers created as a result of Progress Payment.
Just creating a progress payment does not relieve the commitment. The General Ledger Post program (R09801) calls the Update Commitment Ledger (X00COM) that actually relieves the commitment. Committed amounts are relieved from the Purchase Amounts (PA) ledger and are added to the Actual Amount (AA) ledger.
When vouchers or receipts are posted, the system:
Relieves the commitment.
Creates an audit trail in the purchasing ledger file.
Recalculates the amounts in the account balances ledgers, if necessary.
Changes the exchange rate of selected purchase orders and restates the domestic commitment amounts, if necessary.
When you inquire on commitments, the receipt general ledger date, not the original subcontract general ledger date, is used to relieve the commitment.
If the Expense At Voucher option is selected on the Line Type Constants Revisions form, then the system relieves commitments when posting the voucher match batch. This applies to two-way and three-way voucher match. Expense at voucher works like two-way match. The expense is vouchered as a three-way match but because there are no general ledger records from receipts the expense at voucher functions like a two-way match. Thus, the commitment relief is for the voucher amount and not the receipt amount.
See Order Line Types.
In addition to the entries that are made to the subcontract tables during order entry and progress payment processing, the system also maintains commitment information in these tables:
F43199
Account Balances (F0902)
The system creates multiple entries in the F43199 table. Based on change orders, order activity rules, and commitments, the system maintains these multiple ledgers to satisfy the business requirements:
Purchasing (Subcontractor) Ledger.
Commitment Audit Trail (PA/PU Ledger).
Change Order Ledger (CO Ledger).
Note: The processing option prompts for either change orders or commitments. The F43199 commitment and commitment relief record can be reviewed on Commitment Inquiry P40230A. |
If you are tracking commitments, a commitment audit trail transaction is created in the F43199 table. The committed amounts are maintained in the Purchase Amounts (PA) ledger and any committed units are maintained in the Purchase Units (PU) ledger. When you review the PA or PU ledger, you notice that, unlike the purchasing ledger, the Last and Next status code fields are blank.
Each commitment transaction represents one of these situations:
The entry of an original commitment.
A change to a commitment.
A canceled commitment.
A relieved commitment due to a receipt or payment.
During subcontract entry, the system creates a commitment entry in the PA and PU ledgers in the F0902 table. Based on the general ledger date, the system creates an entry in the appropriate accounting period and adds the committed amount to the total budgeted amount.
If the Commitment Relief constant is set to Y, the system posts the receipt payment to the PA and PU ledgers in the F0902 table. Based on the general ledger date of the progress payment, the system relieves the commitment from the appropriate period and the total budgeted amount.
Before you complete the tasks in this section:
Set up the document types for pre-encumbrances and commitments in UDC 40/CT.
Set the Commitment Relief value for the transaction company or company 0000 in the Job Cost Constants program (P0026) to relieve commitments.
This section provides an overview of the Commitment Integrity Report and discusses how to:
Run the Commitment Integrity Report (R40910).
Set processing options for the Commitment Integrity Report (R40910).
You can generate a Commitment Integrity Report (R40910) to compare the open order amounts against the committed amounts and amount balances and to review any variances.
Use the Commitment Integrity Report program (R40910) to indicate variances among these tables:
F4311
F43199
F0902
Two comparisons are made to identify out-of-balance conditions between files.
The detail file and the audit file are compared on a to-date basis, which means that all data in the files is summed regardless of date. The detail file is not date sensitive and does not contain information such as when you made changes to the open amount.
The system compares the audit file and the balances file on a through-period-end basis. The system uses the date that you enter for the first processing option to determine the period end date to use. This comparison is period-sensitive because that is the lowest level of detail stored in the balances file.
The columns under Balance to Date on the left side of the report are Purchase Order Detail File, P.O. Detail Ledger File - Flexible Version, and Variance. The amounts reported by account number and subledger are:
Open amount in the detail file.
Total of the commitment audit trail transactions.
Difference between the two columns.
The columns under Balance as of xx/xx/xx on the right side of the report are P.O. Detail Ledger File - Flexible Version, Account Balances, and variance. The amounts reported by account number and subledger are:
Total of the Commitment Audit Trail transactions.
Account Balances total.
Variances occur between the F4311 table and the Commitment Audit Trail under these conditions:
Unposted receipt or voucher batches.
To confirm that all O and V batches are posted, run the Unposted Batches report (R007011).
Subcontracts on budget hold.
The system does not create a commitment until a subcontract is released from budget hold.
If you find an inconsistency in the commitments that cannot be resolved, you can correct the information in the PA ledger. All entries in the PA and PU ledgers are based on the F4311 table. You can rebuild this information from the F4311 table and correct any inconsistencies in the F0902 table.
Select Subcontract Reports (G43D111), Commitment Integrity Report.
Processing options enable you to specify the default processing for programs and reports.
Specify the effective date to use in the comparison between the Audit Trail and Account Balance files. If you leave this processing option blank, the system uses the current date.
Although processing options are set up during EnterpriseOne implementation, you can change processing options each time you run a program.
Specify the number of records that the system displays on the report. Values are:
Blank: Print all accounts with and without variances.
1: Print all accounts with commitment variances.
Specify whether to run the program in proof or final mode.
In proof mode, the system compares the F4311 table to the F43199 table to date, and also compares the F43199 table to the F0902 table, based on the Effective Date processing option. In final mode, the system displays these comparisons and writes temporary records to the F43199 and F0902 tables to remove the variances. Oracle recommends that you run the purge, rebuild, and repost programs to bring all records into balance. Values are:
Blank: Proof mode
1: Final mode
Specify whether the system processes financial encumbrances that are associated with manufacturing work orders. Values are:
Blank: The system processes financial encumbrances that are related to purchase orders and subcontracts.
1: The system processes financial encumbrances that are related to purchase orders, subcontracts, and manufacturing work orders.
This section provides an overview of commitment information for subcontracts and discusses how to:
Set processing options for Commitment Inquiry (P40230A).
Review detailed commitment information.
You can monitor individual commitment amounts for a job or project to verify the types of subcontracts being made. You can also review the total commitment amount for a job or project to verify that the amount does not exceed the budget.
After you process progress payments, you can have the system relieve commitments. The system does this by reducing the total commitment amount for a job or project by the individual commitment amount. The system relieves open commitments when you post progress payment vouchers to the general ledger.
The system performs commitment tracking only on order types that you specify in UDC 40/CT. If a subcontract is on hold, the system does not create commitments for the subcontract until you release the hold.
The system tracks only commitments for detail lines that you charge directly to a general ledger account number. These are detail lines to which you assign a line type with an inventory interface of A or B. For subcontracts, typically line type J is used.
Each time you enter a subcontract detail line for which commitment tracking applies, the system records the amount in the Purchase Amount (PA) ledger, which contains committed purchase amounts in domestic currency, and the Purchase Units (PU) ledger, which contains committed purchase units.
You can review individual commitment transactions for:
A job/project.
An account number or a cost code or cost type.
A subcontractor (supplier).
A subcontract and type.
You can also review the total amount of all commitments, relieved commitments, and open commitments for each of these individual commitment transactions.
You can review details for each transaction, such as the account number, subcontract number, line number, and subcontractor, as well as who generated the transaction and when.
The system retrieves commitment transaction information from the F43199 table.
Specify a UDC (00/DT) that identifies the type of document.
This code also indicates the origin of the transaction. Oracle has reserved document type codes for vouchers, invoices, receipts, and time sheets, which create automatic offset entries during the post program. (These entries are not self-balancing when you originally enter them.)
These document types are predefined, and Oracle recommends that you not change them. Values are:
P: Accounts Payable.
R: Accounts Receivable.
T: Payroll.
I: Inventory.
O: Purchase Order Processing.
J: General Accounting/Joint Interest Billing.
S: Sales Order Processing.
Specify whether to display change orders or commitments. Values are:
1: Change Orders.
Blank: Commitments.
Specify which version of Purchase Order Entry to call. If this processing option is left blank, then the system uses ZJDE0001.
Access the Commitment Inquiry Detail form.
Figure 5-1 Commitment Inquiry Detail form
This section provides an overview of the Encumbrance Rollover program and discusses how to:
Run the Encumbrance Rollover program (R4317).
Set processing options for Encumbrance Rollover (R4317).
When you run the Encumbrance Rollover program (R4317), the system rolls forward the fiscal year end commitments. The rollover reduces the manual effort placed on users who work in environments with a high volume of transactions. The Encumbrance Rollover program enables you to perform one of these actions:
Relieve committed lines on a subcontract from the prior year and recommit a new line with the current year's general ledger date. These lines are assigned to a new account that is created especially for this rollover. This account is controlled through distribution automatic accounting instruction (AAI) 4430.
Cancel committed lines on a subcontract to ensure that no further payment processing can be made against those lines. For subcontracts, the purge code must be R. For purchase orders, the system updates the next status to 999 (closed).
Many industries use the term decommit to relieve commitments. When you relieve or decommit commitments, the system creates an RO ledger type record. You should not purge the RO records, because they must be used to create or rebuild commitments.
Select Procurement Advanced & Technical Ops (G43A31), Encumbrance Rollover.
These processing options specify the defaults that the system applies when you run an encumbrance or commitment rollover.
Specify how the system processes year-end encumbrance amounts.
The method that you use depends on the business requirements. Values are:
Blank: The system cancels rollover with no further action. No amount is recommitted to a new general ledger date or account.
1: The system uses a new general ledger date.
2: The system uses a new general ledger date and a new account number.
Specify the general ledger class code that the system uses to retrieve the AAIs.
You can enter a general ledger class code or leave the processing option blank to use the general ledger class code from the purchase order detail line. If you are processing subcontracts with account reclassification, you must enter a general ledger class code.
If you are processing both purchase orders and subcontracts, the general ledger class code that you enter is used for both. This code determines the A/R account (class) that is offset when you post invoices. The code that you enter in this processing option can be alphanumeric or can match the object code of the general ledger account number.
Note: Do not use code 9999. The system reserves this code for the post program and indicates that offsets are not created. |
Specify the ledger type that the system uses for the history record in the F43199 table.
This is a UDC (09/LT) that specifies the type of ledger, such as AA (actual amounts), BA (budget amount), or AU (actual units).
Specify the general ledger date for the current year's encumbrance rollover.
This date identifies the financial period to which the transaction is posted. You set up the date range for each financial period in general accounting constants.
Specify the general ledger date to decommit, or relieve, the encumbrance.
This date identifies the financial period to which the transactions are posted. You set up the date range for each financial period in the general accounting constants.
This processing option specifies whether to process the rollover in proof or final mode.
Specify whether the system runs the encumbrance rollover in proof or final mode.
When you run the encumbrance rollover in proof mode, the system does not update the status or any applicable tables.
When you run the encumbrance rollover in final mode, the system updates the status and all applicable tables. Whether you run the encumbrance rollover in proof or final mode, you can print journal entries and errors. Values are:
Blank: Proof mode
1: Final mode
These processing options specify how the system processes manufacturing data.
Specify whether to process financial encumbrances that are associated with manufacturing work orders. Values are:
Blank: Process financial encumbrances that are related to purchase orders and subcontracts.
1: Process financial encumbrances that are related to purchase orders, subcontracts, and manufacturing work orders.
Specify the work order status that the system uses to close open work orders.
You can also specify the work order status that the system uses to determine whether an order is open. The system processes only work orders for which the status is less than the closed work order status that you specify in this processing option. If you leave this processing option blank, the system uses status 99 (close) as the default.
This section provides overviews of commitment audit trails, the Create Commitment Audit Trail program, and corrections to commitment audit trails, lists prerequisites, and discusses how to run the Create Commitment Audit Trail program (R00993).
A commitment audit trail is a history of commitment balances. For example, you might want to create a commitment audit trail to track amounts on subcontracts and changes to those subcontracts.
You can correct the commitment audit trail if you locate data inconsistencies among any of these tables:
F4311
F43199
F0902
If the business needs change after you install the JD Edwards EnterpriseOne Subcontract Management system, you might need to create a commitment audit trail for the orders. You can run the Create F43199 Commitment Audit Trail program (R00993) to create a history of commitment balances.
When you run the Create F43199 Commitment Audit Trail program, the system creates an audit trail record of commitments against an order with an account number. When you create an audit trail, the system reads the F4311 table and writes the audit trail data, one line at a time, to the F43199 table. Purchase orders that have audit trails have a Purchase Amount (PA) ledger type in the F43199 table. The system also reads the F43121 records to record the decommit records.
The system processes only detail lines that have a document type that is specified in the UDC table for commitment document types (40/CT). Additionally, the system does not create a commitment audit trail for records in which an audit trail already exists. Therefore, to re-create a commitment, you must first purge existing records.
You can correct the commitment audit trail if you locate data inconsistencies between any of these tables:
F4311
F43199
F0902
To correct the commitment audit trail, you must purge the current commitment audit trail to prevent duplicating the commitment amounts in the new commitment audit trail. Purge only records in the F43199 table with a ledger type of PA and a next status and last status of blank. Select one of these data dictionary aliases:
Ledger Type (LT)
Next Status (NXTR)
Last Status (LTTR)
Important: Use caution when selecting records to purge. The F43199 table contains records for the Purchasing ledger (blank ledger type), Change Order ledger (CO ledger type), rollovers (RO ledger type), and commitment records (PA and PU ledger types). If you purge purchasing ledger, change order, and rollover ledger records, you cannot recover the records. |
Note: You can use selection criteria to narrow the scope of information that the system purges and uses to create the new audit trail. For example, you can use account numbers, contract numbers, or order numbers. The selection criteria that you use to purge the audit trail must be the same criteria that you use to create the new audit trail. If they are not, unpredictable results may occur.After you purge the F43199 table, you must create a new commitment audit trail. The system creates the new commitment audit trail from records in the F4311 table for both open and closed orders. Open orders have records in the audit trail for the original commitment amount and any amounts that have been partially relieved. All partially relieved records for each order are summarized into one relief record. Closed orders have two records posted in the commitment audit trail: one record for the original commitment amount and another for the commitment relief. After you create the new commitment audit trail, run Repost Committed Costs (R00932) to repost the PA ledger records in the F0902 table. The system adds the new information in the audit trail and posts these amounts to the F0902 table. |
Before you run the Create Commitment Audit Trail program (R00993) to create the commitment audit trail, you must purge the commitment information that currently exists in the F43199 table. Verify that you are deleting information only from the PA ledger.
Note: Commitments record only for document types in UDC 40/CT and for line types using inventory Interface of A, B, or C. |
Before you run the Create Commitment Audit Trail program (R00993) to correct the commitment audit trail:
Verify that the data inconsistencies are in the F43199 table and not in the F0902 table. If the data inconsistencies are in only the F0902 table, you can correct the inconsistencies by running Repost Committed Costs (R00932) to repost the F0902 table.
Back up the F4311, F43199, and F0902 tables.
This section provides an overview of the Post Committed Cost to Job program and discusses how to:
Run the Post Committed Cost to Job program (R00932).
Set processing options for Post Committed Cost to Job (R00932).
Run the Post Committed Cost to Job program (R00932) to track the job costs. When you run this program, the system recalculates the amounts in the F0902 table for the Purchase Amount (PA) and Purchase Unit (PU) ledgers. The system also recalculates monthly amounts in the F0902 table based on information in the F43199 table.
Select Subcontract Setup/Rebuild (G43D411), Post Committed Cost to Job.
Specify the fiscal year in which to begin reposting committed costs.
For example, a fiscal year begins October 1, 2008 and ends September 30, 2009. The end of the first period is October 31, 2008. Specify the year 08 rather than 09. If this processing is left blank, the system supplies a zero, causing the from fiscal year to be 00.
Specify the fiscal year in which to end reposting committed costs. If this processing option is left blank, the system uses the fiscal year that you specify in the Fiscal Year From processing option.
Blank: The system processes purchase orders and subcontracts.
1: The system processes purchase orders, subcontracts, and manufacturing work orders.
