This chapter contains the following topics:
The logic for validating tax IDs for customers and suppliers for Latin American users in countries for which localized solutions are available is different from the logic for users in other countries. JD Edwards EnterpriseOne software supports localized software for these Latin American countries:
Argentina
Brazil
Chile
Colombia
Ecuador
Mexico
Peru
Venezuela
The standard logic for validating tax IDs uses the country code of the customer or supplier, along with values in the Tax Id Validation (70/TI) user-defined code (UDC) table. For the Latin American countries, the logic uses the user's country code as set up in the User Profile Revisions program (P0092) when:
The user's country code is different from the supplier or customer country code, and
The user's country code is for a supported Latin American country.
For example, if the user's country code is EC (Ecuador) and the supplier's country code is IT (Italy), the system:
Verifies that the IT value exists in the 70/TI UDC table.
Uses the validation routine for Ecuador instead of the validation routine for Italy.
The tax ID validation system for Ecuador does not allow duplicate tax ID numbers, except for related parent address book numbers. When you enter a new address number record and specify that there is an existing address book parent record with the same Tax ID, the system allows that duplicity.
Use tax area types to specify whether a tax area is for solidarity, withholding, or VAT. Tax rate/areas are stored in the F4008 table.
You should set up tax rate/areas within a structure, for example, A BBB CCC D. This table represents how you can set up the structure:
| Character | Example |
| A (Tax type) | G (General VAT) |
| BBB (Tax concept) | COM (Purchasing)
HON (Fees) SER (Services CMI (Commissions) ARR (Leasing) M (Manual tax settlement) Note: Use M when no specific VAT or withholding percentage exists and the tax calculation is entered manually. |
| CCC (Tax subgroup) | For COM (Purchasing):
For SER (Services):
For ARR (Leasing):
For M (Manual tax settlement):
Using this example, tax areas could be:
GCOMGEN – General VAT for automatic general purchases.
EHONGENM – Manual exempt general fees.
Set up the first line of the tax area for rent withholding and the second line for VAT withholding.
Colombian and Ecuadorian localizations use four tax explanation codes from the Tax Explanation Codes (00/EX) UDC table:
C: VAT + Sales tax
V: VAT
CT: VAT + Sales tax, tax only
VT: VAT, tax only
These tax explanation codes are hard-coded for the JD Edwards EnterpriseOne Accounts Payable and JD Edwards EnterpriseOne Accounts Receivable systems.
This table lists the country-specific setup and functionality for Ecuador:
| Setup or Process | Description |
| UDCs (user-defined codes) | In addition to the base software UDCs:
| Automatic accounting instructions | No Ecuadoran-specific AAI setup exists. |
| Next numbers | You must set up next numbering by company before you can process withholding certificates for rent and value-added taxes (VAT) withholding. |
| Address book records | The logic for validating tax IDs for customers and suppliers is different in the Address Book Revisions program (P01012) for users in the Latin American countries supported by JD Edwards EnterpriseOne software.
See How to Validate Tax IDs in Latin American Countries. In addition to entering the standard information for address book records, in Ecuador, enter country-specific information for tax reporting. See Entering Additional Address Book Information for Ecuador. |
| Tax processing | Ecuador-specific setup or functionality exists for:
| Payment processing | To process payment vouchers for Ecuador, you must set processing options for the Print Automatic Payments Check (R76E0001) program. |
