This chapter contains the following topics:
Section 4.1, "Understanding Electronic Tax Reporting for Germany"
Section 4.3, "Creating or Modifying Data Extraction Programs"
The German Federal Agency of Finance (Bundesamt für Finanzen) requires businesses operating in Germany to provide electronic access to copies of accounting data according to an audit process detailed in the document Grundsätze zum Datensugriff und zur Prüfbarkeit digitaler Unterlagen (GDPdU). Data from live data processing systems must be extracted and provided to tax auditors on industry-standard digital media such as a CD-ROM or DVD.
JD Edwards EnterpriseOne software provides the tools that enable businesses to extract relevant tax data from JD Edwards EnterpriseOne tables and write the data to text files. You send the text files, along with an index that explains the data and a copy of the DTD (document type definition) that is used with the index, to the tax auditors. Table extraction programs are provided to extract data from the Customer Ledger table (F03B11), the Accounts Payable Ledger table (F0411), the Account Ledger table (F0911), and the Taxes table (F0018). Additionally, an XML-formatted index that you must modify to meet reporting requirements, and a copy of the gdpdu-01–08–2002 DTD are provided on the My Oracle Support web site under document ID 987747.1.
Important: The provided solution might not provide the needed data for every situation. For example, if the tax authority requests information that does not reside in the F03B11, F0411, F0911, or F0018 tables, or you have customized your installation to store tax data in alternate fields in these tables or other tables, you must create your own table conversions to extract data from other JD Edwards EnterpriseOne tables, or modify the data extraction programs provided to alter the output produced by the programs.You can use the provided data extraction programs as models for new data extraction programs. However, you must refer to official government publications for the requirements of the data and formatting required. |
See JD Edwards EnterpriseOne Tools Table Conversion Guide
To generate and review the data to submit to the tax authority:
Run the data extraction programs to create text files.
The data extraction programs create a file that is semicolon (;) delimited and which has double-quote (") text encapsulation. The system saves the text files to the Export folder for your JD Edwards EnterpriseOne installation. JD Edwards EnterpriseOne software provides data conversion programs for some tables; you might need to create your own programs if you need to report on data that resides in other tables. Additionally, you might need to modify the provided data extraction programs prior to running them to create the text files.
Review the text files as necessary.
You can open the text files in any program that reads .txt files. If you need to add or delete columns in the text files due to customizations, consider modifying the data extraction programs and then run the programs again.
Modify the Index.XML file to include relevant data about the data submission, your company, the dates for which you generated the text files, and records that are not included in the sample Index.XML provided.
You can open and modify the Index.XML file in any program that reads XML files. However, they are easier to read and modify in an XML editor.
In addition to the information about your company and the reporting dates, you must modify the XML file to include information about additional data if the provided data extraction programs are modified or if you create additional data extraction programs that produce new .txt files.
Submit the text files, your modified version of the Index.XML file, and an unmodified version of the gdpdu-01–08–2002 DTD to the tax audit authority on industry-standard digital media such as a CD-ROM or DVD.
This graphic illustrates the process flow for extracting data and submitting files:
Figure 4-1 Process flow for extracting data and submitting files
Before completing the tasks in this section:
Verify that an Export folder exists in the installation directory for the version of the software that you use.
If you run the data extraction programs from a FAT client installation on a PC, the Export folder must exist in the installation directory on the PC. For example, your installation directory with the Export folder might be C:\B10\PD10\Export.
If you run the data extraction programs from a web client on a PC or from a server, the Export folder must exist in the installation directory on the server.
Verify that the user running the report has write privileges for the Export folder.
Because your company might have modified the delivered base software, and because the audit authority might request different data from time to time, the software cannot be programmed to determine the exact data that might be required for an audit. The provided solution is meant to provide you with the tools and examples to produce the data and data descriptions that might be required. You must modify the data extraction programs and the .XML file provided to meet the requirements of data reporting. Additionally, you might need to create other data extraction (table conversion) programs to produce required data.
Note: Whenever you make a modification to a data extraction program or create a new program, you change the text files that you submit to the tax authority. Because the Index.XML file describes the text files, you must also modify the Index.XML file to reflect any changes to the text files. |
If creating new program or modifying a provided data extraction program, consider these factors:
File formats can be variable length or fixed length.
Variable length fields can be formatted as alphanumeric, numeric, or as a date.
The data extraction programs provided are variable length.
In variable length files, text files can be encapsulated.
The text files produced by the provided data extraction programs are encapsulated with double quotes ("). The text files are semi-colon (;) delimited.
For each table for which you provide data, you must include in the Index.XML file a description of the data, including:
URL
Name of the table.
Description of the table.
Date range of the data extracted.
Date format.
Decimal separator.
Digit grouping symbol.
This symbol defines the thousand-separator.
Description of the variable length or fixed length text, including whether the fields are alphanumeric, numeric, or a date.
Refer to the official government publication for details of the data to include in your text and Index.XML files.
This section provides an overview of the extraction programs and discusses how to:
Run the F0018 GDPdU Data Extract program (R89F0018G).
Run the F03B11 GDPdU Data Extract program (R89F03B11G).
Run the F0411 GDPdU Data Extract program (R89F0411G).
Run the F0911 GDPdU Data Extract program (R89F0911G).
Most tax-relevant data resides in the F0911, F0411, F03B11, and F0018 tables. When you run the extraction programs for these tables, the system generates a text file that it writes to the Export folder of the installation directory. The system does not generate a report when you run these programs. The text files are semi-colon (;) delimited with double quote (") text encapsulation.
Information about transactions that might be subject to review by the tax authority might be written to more than one table. For example, the taxable amount of a transaction (data item ATXA) might be written to both the F0411 and the F0018 tables. The system extracts all data in a table, even when that data is duplicated in another table.
Note: If data requested by the tax authority does not reside in the F0911, F0411, F03B11, or F0018 tables, you must create custom table conversion programs to extract the additional data and modify the Index.XML file to describe the additional data. |
The XJDE0001 versions of the R89F03B11G, R89F0411G, and the R89F0018G data extraction programs do not include any data selection. You can use any of the fields that reside in the table for which you generate the text file to specify the records that the system includes in the text file that you generate. At a minimum, specify the dates for which the system selects records to process. Record in the Index.XML file the date range for which you extract data.
The XJDE0001 version of the R89F0911G data extraction program is set to select records with the ledger type of AA. Tax information and Accounts Payable and Accounts Receivable accounting information resides in the AA ledger. As with the other data extraction programs, at a minimum, specify the dates for which the system selects records to process. Record in the Index.XML file the date range for which you extract data.
When you run the F0018 GDPdU Data Extraction program, the system generates a text file named F0018GDPDU.txt, and writes the file to the Export directory for your installation.
The system writes data for the selected records for the data items listed in this table, in the order listed.
(Release 9.1 Update) Note: If a field in this file is for a number, the field includes the number of decimals in an XML Accuracy element within the field's XML tag. For example, the field STAM is for the tax amount. This field includes the Accuracy tag. |
| Fields | Description of Values |
| DOCO | Document number (Order No,Invoice,etc.). |
| DCTO | Document type. |
| KCOO | Order company. |
| SFXO | Document pay item number. |
| LNID | Line number. |
| UPMJ | Update date. |
| UPMT | Update time. |
| DCTO Description | Document type value description.The extraction program calls Get UDC(X0005) for 00/DT UDC (userdefinedcode) and writes the description to the text file. |
| KCOO Description | Document company value description.The extraction program calls Get Company Name(B0000051) and writes the description to the text file. |
| CO | Company |
| CO description | Company description
The extraction program calls GetCompanyName (B0000051) and writes the description to the text file. |
| MCU | Business unit. |
| MCU description | Business unit value description.
The extraction program calls IsColumnInBusinessUnitTable (ISCOLBU) and writes the description to the text file. |
| OBJ | Object |
| SUB | Subsidiary |
| AN8 | Address number |
| AN8 description | Address number value description.
The extraction program calls GetAddressBookDescriptionA7 (GETABDA7) and writes the description to the text file. |
| ECST | Amount extended cost. |
| AEXP | Amount extended price. |
| ATXN | Amount – nontaxable. |
| ATXA | Amount – taxable. |
| NRTA | Amount – nonrecoverable tax. |
| STAM | Amount – tax. |
| TXA1 | Tax area 1. |
| TXA1 description | Tax rate/area 1 value description.
The extraction program calls EditTaxRateArea (B0000140) and writes the description to the text file. |
| EXR1 | Tax explanation 1. |
| EXR1 description | Tax explanation 1 value description.
The extraction program calls GetUDC (X0005) for the Tax Explanation Code (00/EX) UDC and writes the description to the text file. |
| EXR2 | Tax explanation 2. |
| EXR2 description | Tax explanation 2 value description.
| TRDJ | Transaction date. |
| DGL | Date – G/L date. |
| DSVJ | Service/tax date. |
| TX | Taxable Y/N |
| ITM | Item description. |
| ITM description. | Item description value description.
The extraction program calls GetItemMasterByShortItem (X4101) and writes the description to the text file. |
| LITM | Second item number. |
| LITM description | Second item number value description.
The extraction program calls GetSecondItemDescription (B4100321) and writes the description to the text file. |
| AITM | Third item number. |
| AITM description | Third item number value description.
The extraction program calls GetThirdItemDescription (B4100322) and writes the description to the text file. |
| LNTY | Line type. |
| LNTY description | Line type value description.
The extraction program calls GetLineTypeConstants (B4000260) and writes the description to the text file. |
| UORG | Units – order/transaction quantity. |
| UOM | Unit of measure. |
| UOM description | Unit of measure value description.
The extraction program calls GetUDC (X0005) for the Unit of Measure (00/UM) UDC and writes the description to the text file. |
| FVTY | Factor value – type. |
| FVTY description. | Factor value – type value description.
The extraction program calls GetUDC (X0005) for H00/FV UDC and writes the description to the text file. |
| TA1 | Tax authority 1 |
| TA1 description | Tax authority 1 value description.
| TXR1 | Tax rate 1. |
| TA2 | Tax authority 2 |
| TA2 description | Tax authority 2 value description.
| TXR2 | Tax rate 2. |
| TA3 | Tax authority 3 |
| TA3 description | Tax authority 3 value description.
| TXR3 | Tax rate 3. |
| TA4 | Tax authority 4 |
| TA4 description | Tax authority 4 value description.
| TXR4 | Tax rate 4. |
| TA5 | Tax authority 5. |
| TA5 description | Tax authority 5 value description.
| TXR5 | Tax rate 5. |
| STA1 | Tax amount 1. |
| STA2 | Tax amount 2. |
| STA3 | Tax amount 3. |
| STA4 | Tax amount 4. |
| STA5 | Tax amount 5. |
| OVTX | Tax override. |
| TXVA | Amount – tax variance. |
| TXVR | Percent – tax variance. |
| POST | G/L posted code. |
| GDVL | Amount – goods value. |
| CRCD | Currency code – from |
| CRCD description | Currency code value description
The extraction program calls F0013GetCurrencyDescription (B03B0103) and writes the description to the text file. |
| CRR | Currency conversion rate |
| SQNO | Sequence number. |
| AG | Amount – gross. |
| APD | Amount – paid. |
| TAXE | Amount – sales tax exempt. |
| DOC | Document number. |
| PROCFL | Tax processing flag. |
| ADJFL | Value-added tax (VAT) adjustment flag. |
| TOFL | Transaction origin flag. |
When you run the F03B11 GDPdU Data Extraction program, the system generates a text file named F03B11GDPDU.txt, and writes the file to the Export directory for your installation. The system writes data for the selected records for the data items listed in this table, in the order listed.
| Fields | Description of Value |
| DOC | Document number |
| DCT | Document type. |
| KCO | Document company. |
| SFX | Document pay item number. |
| DCT description | Document type value description.
The extraction program calls GetUDC (X0005) for 00/DT UDC and writes the description to the text file. |
| KCO description | Document company value description.
| DGJ | Date – G/L. |
| DIVJ | Date – invoice. |
| FY | Fiscal year |
| CTRY | Century |
| PN | Period number |
| CO | Company |
| PA8 | Address number – parent. |
| PA8 description | Address number – parent value description.
| AN8J | Address number – alternate payee. |
| AN8J description | Address number – alternate payee value description.
| PYR | Address number – payor. |
| PYR description | Address number – payor value description.
| POST | G/L posted code |
| ISTR | A/R post status |
| PST | Pay status code |
| PST description | Pay status code value description.
The extraction program calls GetUDC (X0005) for the Payment Status (00/PS) UDC and writes the description to the text file. |
| AG | Amount – gross |
| AAP | Amount – open |
| ATXA | Amount – taxable |
| ATXN | Amount – non-taxable |
| STAM | Amount – tax |
| BCRC | Currency code – base. |
| BCRC description | Currency code – base value description.
| ACR | Amount – foreign |
| FAP | Amount – foreign open |
| CTXA | Amount – foreign taxable |
| CTXN | Amount – non-foreign taxable. |
| CTAM | Amount – foreign tax. |
| TXA1 | Tax rate/area 1 |
| EXR1 | Tax explanation. |
| EXR1 description | Tax explanation value description.
| DSVJ | Date – service/tax. |
| GLBA | G/L bank account. |
| GLBA description | G/L bank account value description.
The extraction program calls RetrieveAccountMasterInfoGLPost (B0900104) and writes the description to the text file. |
| RSCO | Write-off reason code. |
| RSCO description | Write-off reason code value description.
The extraction program calls GetUDC (X0005) for the Reason Code (03B/RC) UDC and writes the description to the text file. |
| VLDT | Date – cleared/value. |
| RMK | Name – remark. |
| ALPH | Name – alpha. |
| RYIN | Payment instrument. |
| RYIN description | Payment instrument value description.
The extraction program calls GetUDC (X0005) for the Payment Instrument (00/PY) UDC and writes the description to the text file. |
| VDGJ | Void date. |
| VOD | Void flag. |
| JCL | Date – invoice close. |
| DDEX | Deduction reason code. |
| DDEX description | Deduction reason code value description.
The extraction program calls GetUDC (X0005) for the Deduction Reason Code (03B/CR) UDC and writes the description to the text file. |
| DTXS | Deferred tax status - VAT. |
| ATAD | Amount – to distribute. |
| CTAD | Amount – foreign to distribute. |
| FNRT | Amount – foreign nonrecoverable tax. |
| SOTF | Sales order tax flag. |
| ERDJ | Date – for exchange rate. |
| AJCL | Date – actual invoice closed. |
When you run the F0411 GDPdU Data Extraction program, the system generates a text file named F0411GDPDU.txt, and writes the file to the Export directory for your installation. The system writes data for the selected records for the data items listed in this table, in the order listed.
| SFX | Document pay item number |
| SFXE | Pay item extension number |
| DCTA | Document type – adjusting |
| DCTA description | Document type – adjusting value description.
The extraction program calls GetUDC (X0005) for the Document Type (00/DT) UDC and writes the description to the text file. |
| PYE | Address number – payee |
| PYE description | Address number – payee value description.
| DIVJ | Date – invoice |
| DSVJ | Date – service/tax |
| DGJ | Date – G/L |
| FY | Fiscal year |
| CTRY | Century |
| CO | Company |
| EXR1 | Tax explanation |
| VOD | Void flag. |
| VINV | Supplier invoice number. |
| PYIN | Payment instrument. |
| PYIN description | Payment instrument value description.
| TXA3 | Tax rate/area 3 – withholding. |
| TXA3 description | Tax rate/area 3 – withholding value description.
| EXR3 | Tax explanation 3 – withholding. |
| EXR3 description | Tax explanation 3 – withholding value description.
| AC07 | Category code – address book 07. |
| AC07 description | Category code – address book 07 value description.
The extraction program calls GetUDC (X0005) for the Address Book Category Code 07 (01/07) UDC and writes the description to the text file. |
| TNN | Flag for 1099. |
| DTXS | Deferred tax status – VAT. |
| TAXP | Purchasing taxable Y/N. |
When you run the F0911 GDPdU Data Extraction program, the system generates a text file named F0911GDPDU.txt, and writes the file to the Export directory for your installation. The system writes data for the selected records for the data items listed in this table, in the order listed.
(Release 9.1 Update) Note: If a field in this file is for a number, the field includes the number of decimals in an XML Accuracy element within the field's XML tag. For example, the field Amount includes the Accuracy tag. |
| Field | Description of Value |
| DGJ | G/L date. |
| JELN | Journal entry line number. |
| LT | Ledger type. |
| EXTL | Line extension code. |
| LT description | Ledger type value description.
The extraction program calls IsColInLedgerTypeTable (B0000378) and writes the description to the text file. |
| CO | Company. |
| CO description | Company description.
| OBJ | Object |
| SUB | Subsidiary |
| CTRY | Century |
| FY | Fiscal year |
| AA | Amount |
| EXA | Name – alpha explanation |
| EXR | Name – remark explanation |
| CN | Payment number |
| ALTX | Consumption tax cross reference. |
| DSVJ | Date service/tax |
| BCRC | Currency code – base |
| TXITM | Tax – short item number |
| TXITM description | Tax – short item number value description.
| ACR | Amount currency |
Select GDPdU Data Extraction (G74D1), F0018 Data Extraction.
Select GDPdU Data Extraction (G74D1), F03B11 Data Extraction.
Select GDPdU Data Extraction (G74D1), F0411 Data Extraction.
Select GDPdU Data Extraction (G74D1), F0911 Data Extraction.
The Index.XML file that you must send to the tax authority is provided on the My Oracle Support web site. The text files that you generate using the data extraction programs do not modify the Index.XML file. Rather, the Index.XML provides information about the data in the text files that you generate using the table conversion programs provided with this solution. For example, the Index.XML file includes information about the values in the text file.
Note: Index.XML files that describe the fields in the F0911, F03B11, F0411, and F0018 table are provided on the My Oracle Support web site. An XML file is provided for each release for which data conversion programs are supported. Be sure to download and modify the Index.XML file that corresponds to your release of JD Edwards EnterpriseOne. |
The Index.XML file includes a header area in which you complete this information:
Version
Complete this field with the version number of the medium used to submit the text files, Index.XML file, and DTD.
DataSupplier
Complete these fields with the name and location of the company suppling the data. A Comment field is also provided in which you can enter additional information.
Media
Complete the Media fields with the name and the dates of the media that you send to the tax audit authority.
This image shows the DataSupplier fields as displayed in an XML viewer. Depending on the text file viewer or XML viewer that you use, the data set might look different. However, the content of the fields is the same.
Figure 4-2 Example of DataSupplier fields
For each table for which you extract data, complete:
URL
Enter the physical file name of the text file.
Name
Enter the name of the table.
Description
Enter a description of the table.
Date range and date format
Decimal symbol
Complete this field with the decimal separator that you use.
Complete this field with the symbol used to separate thousands.
Variable length
The data included in the VariableLength section of the Index.XML file includes a listing of the fields included for the specified table as shipped with the software. If you have modified the F0911, F03B11, F0411, or F0018 tables, you must modify the listing of the fields and the descriptions provided. The data further specifies whether a field is alphanumeric, numeric, or a date, and the maximum length of the field.
Review the entire Index.XML file before you send it to the tax audit authority to assure that the data in the Index.XML file accurately describes your submission.
This image shows some of the data items for the F0018 table, as displayed in an XML viewer. Depending on the text file or XML viewer that you use, the data set might look different. However, the content of the fields is the same.
Figure 4-3 Example of VariableLength fields
