This chapter contains the following topics:
When you process payments for vouchers, the system calculates general sales tax (IGV) withholding for suppliers if you set up the supplier for withholding. You must set up suppliers for IGV withholding when you process real estate sales transactions for the supplier or process the rendering of services and construction contracts that are subject to the tax.
You also set up withholding percentages for vouchers for the tax duty payment system (SPOT) withholding. When you process SPOT vouchers for payment, you also withhold a tax amount from the supplier and send the payment to the National Bank. The values that you set up in the Spot Maintenance Percentage (P76P410) program determine whether the system generates a payment to the National Bank and the percentage that is withheld from the supplier.
This section provides an overview of withholding percentages and discusses how to enter withholding percentages for IGV.
You set up withholding percentage amounts for each supplier by IGV concept, minimum withholding amounts, and effective dates. You can set up multiple percentages for a supplier by using different minimum withholding amounts and effective dates. The system uses the percentages that you set up to calculate IGV withholding amounts for payments.
| Form Name | Form ID | Navigation | Usage |
| Work with IGV Withholding Percentage | W76P405A | Accounts Payable (G76P04), Withholding Percentage | View or select existing records. |
| IGV Withholding Percentage Revisions | W76P405B | Click Add on the Work with IGV Withholding Percentage form. | Set up withholding percentages for companies by IGV concept, minimum withholding amount, and effective date. |
Access the IGV Withholding Percentage Revisions form.
Figure 5-1 Edit IGV Withholding Percentage form
Enter the code that identifies the type of IGV withholding. The code that you enter must exist in the IGV Withholding Concept (76P/01) UDC table.
Enter the percentage that specifies the withholding percentage on taxes. The maximum valid amount is 999,99.
Enter the minimum taxable amount to generate the withholding. If the total payment taxable amount is less than the amount specified in this field, the withholding is not applied.
Enter the code that identifies the basis of the minimum amount. For example, you can specify that the system uses the gross amount of the voucher or the taxable amount of the voucher when determining if the voucher amount meets the withholding minimum amount requirement. The code that you enter must exist in the Amount Type to Use (76P/AT) UDC table.
This section provides an overview of SPOT withholding and discusses how to enter SPOT withholding percentages.
You set up codes for the tax duty payment system (Sistema de Pago de Obligaciones Tributarias [SPOT]) that the system uses when you enter vouchers for the tax duty. When you set up the codes, you enter the withholding percentage, the minimum amount on which the system calculates the tax, and the amount type on which the system bases the calculation.
| Work with Spot WH Percentage - 76P | W76P410A | Accounts Payable (G76P04), Spot Maintenance Percentage | View or select existing records. |
| Spot Wh Percentage Revisions | W76P410B | Click Add on the Work with Spot WH Percentage - 76P form. | Enter the withholding percentage, the minimum amount on which the system calculates the tax, and the amount type on which the system bases the calculation. |
Access the Spot Wh Percentage Revisions form.
Figure 5-2 Spot Wh Percentage Revisions form
Enter the code that identifies the type of SPOT withholding. The code that you enter must exist in the SPOT Concepts (76P/02) UDC table.
Enter the code that identifies the basis of the minimum amount. For example, you can specify that the system uses the total of the voucher or the taxable amount of the voucher when determining if the voucher amount meets the withholding minimum amount requirement. The code that you enter must exist in the Amount Type to Use (76P/AT) UDC table.
When you set up suppliers for Peru, you must specify whether the supplier is an individual. If the supplier is an individual, you complete the Person/Corporation field on the Supplier Master Revision form in the Supplier Master Information (P04012) program with 01. You must also complete the fields in the Who's Who program in the JD Edwards EnterpriseOne Address Book system to include the names of the supplier's mother and father. This information is required for reporting to the tax authorities.
