This chapter contains the following topics:
Note: You run the table conversion programs only if you have an installation of a previous version of the JD Edwards EnterpriseOne software for Taiwan. |
Some of the tables for the JD Edwards EnterpriseOne software for Taiwan were changed for release 9.0. If you have a previous version of the software installed, you must run the table conversion programs to move the data in your existing tables to these updated tables:
GUI/VAT Transaction Header (F75T004)
GUI/VAT Transaction Detail (F75T005)
GUI/VAT Transaction Header POS (F75T004P)
GUI/VAT Transaction Detail POS (F75T005P)
GUI/VAT Transaction Header History (F75T0049)
GUI/VAT Transaction Detail History (F75T0059)
The new versions of the tables include additional fields.
This section discusses how to run these table conversion programs:
Table Conversion for F75T004
Table Conversion for F75T005
Table Conversion for F75T004P
Table Conversion for F75T005P
Table Conversion for F75T0049
Table Conversion for F75T0059
Select Table Conversion (G75T151), Table Conversion for F75T004.
Select Table Conversion (G75T151), Table Conversion for F75T004P.
Select Table Conversion (G75T151), Table Conversion for F75T005.
Select Table Conversion (G75T151), Table Conversion for F75T005P.
Select Table Conversion (G75T151), Table Conversion for F75T0049.
This program converts the F75T0059 table.
Select Table Conversion (G75T151), Table Conversion for F75T059.
