This chapter contains the following topics:
Section 1.1, "JD Edwards EnterpriseOne Project Manufacturing Overview"
Section 1.2, "JD Edwards EnterpriseOne Project Manufacturing Business Processes"
Section 1.3, "JD Edwards EnterpriseOne Project Manufacturing Integrations"
Section 1.4, "JD Edwards EnterpriseOne Project Manufacturing Implementation"
JD Edwards EnterpriseOne Project Manufacturing from Oracle supports the manufacturing industry. JD Edwards EnterpriseOne Project Manufacturing enables you to create production controlled items and use unique production numbers to track orders and inventory associated with customer orders.
With JD Edwards EnterpriseOne Project Manufacturing, you can:
Define the structure of production numbers.
Generate production numbers for production controlled items.
Enter forecasts for production controlled items.
Enter sales orders for production controlled items.
Procure materials for the manufacture of production controlled items.
Manage the manufacture of production controlled items.
Manage supply and demand for production controlled items.
Reassign production numbers, orders, and inventory for production controlled items that have no associated demand.
The following process flow illustrates the JD Edward EnterpriseOne Project Manufacturing business processes:
Figure 1-1 JD Edwards EnterpriseOne Project Manufacturing Business Process Flow
We discuss these business processes in the associated business process chapters of this implementation guide.
JD Edwards EnterpriseOne Project Manufacturing is an integrated solution that supports JD Edwards EnterpriseOne base functionality. The system is integrated to support the manufacturing industry.
JD Edwards EnterpriseOne Project Manufacturing is not fully integrated into supply chain management as some base functionality, such as forecast consumption, returned material authorization, and repetitive manufacturing, is not available.
JD Edwards EnterpriseOne Project Manufacturing integrates with these JD Edwards EnterpriseOne products from Oracle:
Figure 1-2 JD Edwards EnterpriseOne Project Manufacturing Product Integrations
We discuss integration considerations in the implementation chapters of this implementation guide.
The JD Edwards EnterpriseOne Financials product from Oracle provides a versatile, cost-effective, and timesaving solution for managing your financial information. You use the systems that comprise the JD Edwards EnterpriseOne Financials product to track information that financial users typically share.
The JD Edwards EnterpriseOne Inventory Management system from Oracle stores item information, sales and purchasing costs, and quantities that are available by location. JD Edwards EnterpriseOne Project Manufacturing uses the JD Edwards EnterpriseOne Inventory Management system to set up production controlled items.
JD Edwards EnterpriseOne Inventory Management enables you to track materials between inventory or storage locations and the shop floor. You can manage inventory issues and commitments, complete orders, and track order quantities throughout the production process.
The JD Edwards EnterpriseOne Manufacturing Management product from Oracle includes several JD Edwards EnterpriseOne systems, including Oracle's JD Edwards EnterpriseOne Shop Floor Management system.
The JD Edwards EnterpriseOne Shop Floor Management system enables you to control the flow of materials inside and outside the plant by managing and tracking manufacturing work orders. It provides an effective way to maintain and communicate information that the system requires to complete production requests.
The JD Edwards EnterpriseOne Procurement and Subcontract Management product from Oracle includes several JD Edwards EnterpriseOne systems, including the JD Edwards EnterpriseOne Procurement system from Oracle.
The JD Edwards EnterpriseOne Procurement system controls all aspects of purchasing activities. JD Edwards EnterpriseOne Procurement enables you to generate purchase orders for raw materials to use in manufacturing items that are production controlled.
The JD Edwards EnterpriseOne Requirements Planning product from Oracle contains several JD Edwards EnterpriseOne systems, including the JD Edwards EnterpriseOne Requirements Planning and JD Edwards EnterpriseOne Forecast Management systems from Oracle.
The JD Edwards EnterpriseOne Requirements Planning system from Oracle uses sales orders and forecasts to pass demand for items down through the bills of material to the components. The system also uses bills of material to determine component requirements for planned orders and work orders without a parts list.
JD Edwards EnterpriseOne Distribution Requirements Planning, JD Edwards EnterpriseOne Master Production Schedule, and JD Edwards EnterpriseOne Material Requirements Planning provide suggested purchasing and manufacturing orders that are required to maintain a valid production schedule.
The JD Edwards EnterpriseOne Forecast Management system generates sales projections that are used to create demand and develop the master production schedule. JD Edwards EnterpriseOne Project Manufacturing uses the JD Edwards EnterpriseOne Forecast Management system to set up forecasts for production controlled items and associated production numbers.
This section provides an overview of the steps that are required to implement JD Edwards EnterpriseOne Project Manufacturing.
In the planning phase of your implementation, take advantage of all Oracle sources of information, including installation guides and troubleshooting information.
When determining which electronic software updates (ESUs) to install for JD Edwards EnterpriseOne Project Manufacturing, use the EnterpriseOne and World Change Assistant. This Java-based tool reduces the time required to search and download ESUs by 75 percent or more and enables you to install multiple ESUs at one time.
See JD Edwards EnterpriseOne Tools Software Updates Guide.
This table lists the suggested global implementation steps for JD Edwards EnterpriseOne Project Manufacturing:
Set up global user-defined code (UDC) tables.
See "Working with User Defined Codes" in the JD Edwards EnterpriseOne Tools System Administration Guide.
Set up fiscal date patterns.
Set up companies.
Set up business units.
Set up next numbers.
(Optional) Set up accounts and the chart of accounts.
Set up General Accounting constants.
Set up multicurrency processing, including currency codes and exchange rates.
See JD Edwards EnterpriseOne Applications Multicurrency Processing Implementation Guide.
(Optional) Set up ledger type rules.
Set up address book records.
Set up default locations and printers.
Set up branch/plant constants.
Set up Manufacturing/Distribution automatic accounting instructions (AAIs).
Set up document types.
Set up shop floor calendars.
Set up manufacturing constants.
This table lists the suggested application-specific implementation steps for JD Edwards EnterpriseOne Project Manufacturing:
Activate JD Edwards EnterpriseOne Project Manufacturing.
See Activating JD Edwards EnterpriseOne Project Manufacturing.
Set up production controlled items.
Define the production number structure.
Generate production numbers.
