This chapter includes these topics:
This chapter provides detailed information about the business interfaces that are available for the Meter Reading business object.
This table lists all of the available interface components:
| Interface Type | Available Interfaces |
| Batch Import Programs | This list includes the batch import programs for the Meter Reading business object: |
| Orchestration (Release 9.1 Update) | Update Meter Readings
For additional information about the Update Meter Readings orchestration, see Section 7.1.2, "Update Meter Readings". |
Note: You can find additional technical information about each type of business interface component. For additional descriptions of the information available, and instructions for finding this information, see Chapter 5, "Accessing Additional Information for Business Interface Components." |
You use batch import programs to import data from an external software system into the JD Edwards EnterpriseOne system, where it can then be processed by EnterpriseOne programs.
This table lists and describes the available batch import programs that are associated with the Meter Reading business object:
