This chapter includes these topics:
This chapter provides detailed information about the business interfaces that are available for the Resource Competency business object.
This table lists all of the available interface components:
| Interface Type | Available Interfaces |
| Real-Time Events | This list includes the real-time events for the Resource Competency business object: |
| Batch Import | This batch import program is available for the Resource Competency business object: |
Note: You can find additional technical information about each type of business interface component. For additional descriptions of the information available, and instructions for finding this information, see Chapter 5, "Accessing Additional Information for Business Interface Components." |
This section describes the available real-time events associated with the Resource Competency business object, which include:
RTSLHDR is a real-time event notification used by JD Edwards EnterpriseOne to notify external systems of changes to competency scales records.
| Event Type | Event Description | Event Category | Event Aggregate | Product Code |
| RTSLOUT | Competency Scale | RTE | Container
Container event for:
05 |
Conceptual Approach
When a user adds, modifies, or deletes scales data from the JD Edwards EnterpriseOne Human Resources system, the system publishes an event. This container event, RTSLOUT, contains two single events RTSLHDR and RTSLDTL.
Objects that Can Initiate the Event
These objects can initiate the RTSLOUT event, and the single events contained within the event:
P05103 - Scale Information
RTSLHDR is a real-time event notification used by JD Edwards EnterpriseOne to notify external systems of changes to competency scales header records (F05103).
| Event Type | Event Description | Event Category | Event Aggregate | Product Code | Data Structure | Event Relationship |
| RTSLHDR | Competency Scale Header | RTE | Single | 05 | D0500871B: Scales Real Time Event Notification B Structure (F05103) | Included in container event RTSLOUT. |
Conceptual Approach
When a user adds, modifies, or deletes scales data from the JD Edwards EnterpriseOne Human Resources system, the system publishes an event. This container event, RTSLOUT, contains two single events RTSLHDR and RTSLDTL. The RTSLHDR event contains all columns from the modified scales header record (F05103) and an action code specifying what action was performed on the data (added, changed, deleted).
RTSLDTL is a real-time event notification used by JD Edwards EnterpriseOne to notify external systems of changes to competency scales detail records (F05119).
| RTSLDTL | Competency Scale Detail | RTE | Single | 05 | D0500871C: Scales Real Time Event Notification C Structure (F05119) | Included in container event RTSLOUT. |
Conceptual Approach
When a user adds, modifies, or deletes scales data from the JD Edwards EnterpriseOne Human Resources system, the system publishes an event. The container event RTSLOUT contains two single events RTSLHDR and RTSLDTL. The RTSLDTL event contains all columns from the modified scales detail record (F05119) and an action code specifying what action was performed on the data.
RTRCOUT is a real-time event notification used by JD Edwards EnterpriseOne to notify external systems of changes to resource competency header records.
| RTRCOUT | Resource Competency | RTE | Container
Container event for RTRCHDR (D0500872B ). |
05 |
Conceptual Approach
When a user adds, modifies, or deletes resource competency data from the JD Edwards EnterpriseOne Human Resources system, the system publishes the RTRCOUT event. The container event RTRCOUT contains one single event RTRCHDR.
These objects can initiate the RTCROUT event:
F05100 - Resource Competency
RTRCHDR is a real-time event notification used by JD Edwards EnterpriseOne to notify external systems of changes to resource competency header records (F05100).
| RTRCHDR | Resource Competency Header | RTE | Single | 05 | D0500872B: Resource Competency Real Time Event Notification B Structure | Included in container event RTRCOUT. |
Conceptual Approach
When a user adds, modifies, or deletes resource competency data from the JD Edwards EnterpriseOne Human Resources system, the system publishes an event. The container event RTRCOUT contains one single event RTRCHDR. The RTRCHDR event contains all columns from the modified resource competency header record (F05100) and an action code specifying what action was performed on the data (added, changed, deleted). Current integrations do not require synchronization of detail data. However, real-time event business function (B0500872) has been designed to implement this functionality in the future if required.
You use batch import programs to retrieve and format data from external systems so that it can be used in the JD Edwards EnterpriseOne system.
This table lists and describes the available batch import programs that are associated with the Resource Competency business object:
