This chapter includes these topics:
This chapter provides detailed information about the business interfaces that are available for the Job business object.
This table lists all of the available interface components:
| Interface Type | Available Interfaces |
| Real-Time Events | This list includes the real-time events for the Job business object: |
Note: You can find additional technical information about each type of business interface component. For additional descriptions of the information available, and instructions for finding this information, see Chapter 5, "Accessing Additional Information for Business Interface Components." |
This section describes the available real-time events associated with the Job business object, which include:
RTJBOUT is a real-time event notification used by JD Edwards EnterpriseOne to notify external systems of changes to job information records (F08001).
| Event Type | Event Description | Event Category | Event Aggregate | Product Code |
| RTJBOUT | Job | RTE | Container
Container event for RTJBOUTB (D0800630B ). |
08 |
Conceptual Approach
When a user adds, modifies, or deletes job information data from the JD Edwards EnterpriseOne Human Resources system, the system publishes an event. The container event RTJBOUT contains one single event RTJBOUTB.
Objects that Can Initiate the Event
These objects can initiate the RTJBOUT event:
P08001 - Job Entry and Evaluation
P08JC - Category Codes Window
P08001US - Job Entry U.S. Legislative/Regulatory Data
P08001CA- Job Entry Canadian Legislative/Regulatory Data
P050011 - Job Evaluation
RTJBOUTB is a real-time event notification used by JD Edwards EnterpriseOne to notify external systems of changes to job information records (F08001).
| Event Type | Event Description | Event Category | Event Aggregate | Product Code | Data Structure | Event Relationship |
| RTJBOUTB | Job Entry and Evaluation | RTE | Single | 08 | D0800630B: Jobs Real Time Event Notification Structure B | Included in container event RTJBOUT. |
Conceptual Approach
When a user adds, modifies, or deletes job information data from the JD Edwards EnterpriseOne Human Resources system, the system publishes an event. The container event RTJBOUT contains one single event RTJBOUTB. The RTJBOUTB event contains all columns from the modified job information record (F08001) and an action code specifying what action was performed on the data (added, changed, deleted).
RTJDOUT is a real-time event notification used by JD Edwards EnterpriseOne to notify external systems of changes to competency based job description records.
| RTJDOUT | Job Description | RTE | Container
Container event for RTJDOUTB (D0800740B). |
08 |
Conceptual Approach
When a user adds, modifies, or deletes competency based job description data in the JD Edwards EnterpriseOne Human Resources system and then runs R080025, Incremental Job Description Changes Outbound Integration program, the system publishes an event. The container event RTJDOUT contains one single event RTJDOUTB.
The N0800741 - Send Job Desc Integration Notice object can initiate the RTJDOUT event, or the single event contained by the event.
RTJDOUTB is a real-time event notification used by JD Edwards EnterpriseOne to notify external systems of changes to competency based job description records.
| RTJDOUTB | Jobs in an Organization | RTE | Single | 08 | D0800740B: Competency Based Job Desc RTE Notify | Included in container event RTJDOUT. |
Conceptual Approach
When a user adds, modifies, or deletes competency based job description data in the JD Edwards EnterpriseOne Human Resources system and then runs R080025, Incremental Job Description Changes Outbound Integration program, the system publishes an event. The container event RTJDOUT contains one single event RTJDOUTB. The RTJDOUTB event contains all columns from the modified competency based job description record and an action code specifying what action was performed on the data (added, changed, deleted).
RTJBUOUT is a real-time event notification used by JD Edwards EnterpriseOne to notify external systems of changes to the organizational business unit/jobs cross reference (F0800601).
| RTJBUOUT | Jobs in Business Unit | RTE | Container
Container event for RTJBUOUTB (D0800770B). |
08 |
Conceptual Approach
When a user adds, modifies, or deletes organizational business unit/jobs cross reference data (F0800601) from the JD Edwards EnterpriseOne system, the system publishes an event. The RTJBUOUT event is a container event activated on the F0800601 table trigger and contains the single event RTJBUOUTB.
These objects can initiate the RTJBUOUT event, and the single event contained by the event:
F0800601 - Organizational Business Unit/Job Cross Reference table trigger
RTJBUOUTB is a real-time event notification used by JD Edwards EnterpriseOne to notify external systems of changes to the organizational business unit/jobs cross reference (F0800601).
| RTJBUOUTB | Org BU /Jobs Cross Reference | RTE | Single | 08 | D0800770B: Data Structure for B0800770 RTE | Included in container event RTJBUOUT. |
Conceptual Approach
When a user adds, modifies, or deletes organizational business unit/jobs cross reference data (F0800601) from the JD Edwards EnterpriseOne system, the system publishes an event. The RTJBUOUT event is a container event activated on the F0800601 table trigger and contains the single event RTJBUOUTB. The RTJBUOUTB event contains all columns from the modified organizational business unit/jobs cross reference record (F0800601) and an action code specifying what action was performed on the data (added, changed, deleted).
