This chapter includes these topics:
Section 60.2, "Inventory Transactions Batch Import Programs"
Section 60.3, "Inventory Transactions Batch Export Programs"
This chapter provides detailed information about the business interfaces that are available for the Inventory Transactions business object.
This table lists all of the available interface components:
| Interface Type | Available Interfaces |
| Batch Import Programs | This list includes the batch import programs for the Inventory Transactions business object: |
| Batch Export Programs | This list includes the batch export programs for the Inventory Transactions business object: |
You use batch import programs to import data from an external software system into the JD Edwards EnterpriseOne system, where it can then be processed by EnterpriseOne programs.
This table lists and describes the available batch import programs that are associated with the Inventory Transactions business object:
You use batch export programs to retrieve and format data from the JD Edwards EnterpriseOne database so that it can be used by an external software system.
This table lists and describes the available batch export programs that are associated with the Item Branch Master business object:
