This chapter includes these topics:
This chapter provides detailed information about the business interfaces that are available for the Order Promising business object.
This table lists all of the available interface components:
This section describes the available real-time events associated with the Order Promising business unit, which include:
OPBOMROUT, which is a container event for these single events:
OPBOMRHDR
OPAPSRTG
OPAPSRLR
OPBOMROUT is used by the JD Edwards EnterpriseOne system to inform third-party systems when a work orders parts list and routing is added, changed, or deleted.
| Event Name | Event Description | Event Type | Event Category | Product Code |
| OPBOMROUT | Configured Item Trans BOMR | RTE | Container
Contains these data structures:
34A |
Conceptual Approach
A work order parts list or routing that has been added, changed, or deleted in the JD Edwards EnterpriseOne system updates the Work Order Parts List (F3111) and the Work Order routing (F3112) tables. When a work order parts list or routing record is modified, an OPBOMROUT real-time event notification is published.
Objects that Can Initiate the Event
These objects can initiate the OPBOMROUT event, and the single events contained within the event:
B3101250 – F3112 Work Order Routings MBF
B3101260 - F3111 Parts List MBF
R31410 – Order Processing
B34A2090 - Publish Transactional Work Order
B34A2070 – Get APS Integration Constants For WO
OPBOMRHDR is used by the JD Edwards EnterpriseOne system to inform third-party systems when a work order is added, changed, or deleted in order to keep the two systems synchronized.
| Event Type | Event Description | Event Category | Event Aggregate | Product Code | Data Structure | Event Relationship |
| OPBOMRHDR | Configured Item Header | RTE | Single | 34A | D34A1140A: Transactional RLR Header Event Notification Canonical | Included in container event OPBOMROUT. |
Conceptual Approach
When a work order is added, modified or deleted in the JD Edwards EnterpriseOne system, and records are created, modified or deleted in the Work Order Master File (F4801) and Work Order Master Tag File (F4801T), this event is used.
OPAPSRTG is used by the JD Edwards EnterpriseOne system to inform third-party systems when a routing is added, changed, or deleted in order to keep the two systems synchronized.
| OPAPSRTG | Configured Item Routing | RTE | Single | 34A | D34A1140B: Transactional RLR Routing Event Notification Canonical | Included in container event OPBOMROUT. |
Conceptual Approach
When a work order routing is added, modified or deleted into JD Edwards EnterpriseOne system, creating, modifying or deleting a record in the Work Order Routing (F3112) table, this event is used.
OPAPSRLR is used by the JD Edwards EnterpriseOne system to inform third-party systems when a work order parts list is added, changed, or deleted in order to keep the two systems synchronized.
| OPAPSRLR | Configured Item Parts/Resource | RTE | Single | 34A | D34A1140C: Transactional RLR Resource List Event Notification Canonical | Included in container event OPBOMROUT. |
Conceptual Approach
When a work order parts list is added, modified or deleted in the JD Edwards EnterpriseOne system, creating, modifying or deleting a record in the Work Order Parts List table (F3111), this event is used.
