This chapter includes these topics:
This chapter provides detailed information about the business interfaces that are available for the Product Data Management business object.
This table lists all of the available interface components:
| Interface Type | Available Interfaces |
| Batch Import and Export Programs | This list includes the batch import and export programs for the Product Data Manufacturing business object:
Note that both the R3003Z1I and R3002Z1I can function as both import and export programs. |
Note: You can find additional technical information about each type of business interface component. For additional descriptions of the information available, and instructions for finding this information, see Chapter 5, "Accessing Additional Information for Business Interface Components." |
You use batch import programs to import data from an external software system into the JD Edwards EnterpriseOne system, where it can then be processed by EnterpriseOne programs.
This table lists and describes the available batch import and export programs that are associated with the Product Data Management business object:
