Glossary
Action
A number that identifies the action for rental contracts. Actions define how rental contracts relate to other system codes.
Generation Method
A user-defined code (54R/TI) that indicates whether the system generates related orders for the rental contract using the interactive method or the batch method.
Action Version
A user-defined value that indicates the version associated with the program specified in the Program field.
Owned Asset Cost Method
A user-defined code (40/CM) that determines the inventory cost method that the system uses when allocating cost for owned assets.
Minimum Rental Period
A user-defined number that the system uses as the minimum rental period. This number is used in combination with the minimum rental period unit of measure.
Default Rental Period
A user-defined number that the system uses as the default rental period. This number is used in combination with the default rental period unit of measure.
