This chapter contains the following topics:
Common Global Implementation (CGI) is an initiative launched by SWIFT, the global provider of secure financial messaging services. The initiative provides a forum that promotes wider acceptance of ISO 20022 as the common XML standard used between corporate enterprises and banks.
This guide includes information about setting up the CGI functionality and working with CGI debit and credit payments.
In addition to the setup described in this guide, you must set up the base software for the particular process you implement. For example, you must follow the steps to set up the base software JD Edwards EnterpriseOne Accounts Payable system in addition to performing the setup for any country-specific functionality for the JD Edwards EnterpriseOne Accounts Payable system.
When determining which electronic software updates (ESUs) to install for JD Edwards EnterpriseOne systems, use the EnterpriseOne and World Change Assistant. EnterpriseOne and World Change Assistant, a Java-based tool, reduces the time required to search and download ESUs by 75 percent or more and enables you to install multiple ESUs at one time.
See the JD Edwards EnterpriseOne Tools Software Updates Guide.
In the planning phase of your implementation, you can use all JD Edwards EnterpriseOne sources of information, including the installation guides and troubleshooting information.
