This chapter contains the following topics:
The Standard Audit File for Tax Purposes (SAF-T) is a standardized XML file used for exporting the accounting information of a company to the tax authorities. The file contains accounting data that can be exported from an original accounting system for a specific time period.
The SAF-T file is based on a directive by the Organization for Economic Co-operation and Development (OECD).
The JD Edwards EnterpriseOne system generates the SAF-T XML report in a version 2.0 format for XML documents using the following steps:
The OECD SAF-T Generic Extractor report (R705001) gathers the required information and produces the intermediate XML file.
The Business Intelligence Publisher (BIP) XSL transformation and report definition converts the intermediate XML file to the legal SAF-T XML file.
You set up UDC values when you process OECD SAF-T XML.
Select a value from the (70/TA) table to set up the address type required for SAF-T reporting. Values are:
| Codes | Description |
| 0 | StreetAddress |
| 1 | PostalAddress |
| 2 | BillingAddress |
| 3 | ShipToAddress |
| 4 | ShipFromAddress |
Select a value from the (70/AS) table to set up the accounting system required for SAF-T reporting.Values are:
| C | Accounting |
| E | Billing, shipping and working |
| F | Invoicing |
| I | Integrated Invoices and Accounts |
| P | Partial Data |
| S | Self Billing |
Select a value from the (70/ER) table to specify the tax exemption reason required for SAF-T reporting. You specify a value in the additional information section from the Work with Tax Area Additional Information program (P704008A). Values are:
| 1 | Healthcare |
| 2 | Social welfare |
| 3 | Education and training |
| Blank |
Select a value from the (70/TT) table to specify the tax type required for SAF-T reporting. You specify a value in the additional information section from the Work with Tax Area Additional Information program (P704008A). Values are:
| Blank | |
| IS | Stamp Duty |
| IVA | Value Added Tax |
Select a value from the (70/TC) table to specify the tax code required for SAF-T reporting. You specify a value in the additional information section from the Work with Tax Area Additional Information program (P704008A).Values are:
| Blank | |
| INT | Intermediate tax rate |
| ISE | Exempted |
| NOR | Normal tax rate |
| OUT | Others |
| RED | Reduced tax rate |
Select a value from the (70/AT) table to specify the account type required for SAF-T reporting. You specify a value in the additional information section from the Work with Account Master Additional Information program (P700901A).Values are:
| 1 | Asset |
| 2 | Liability |
| 3 | Sale |
| 4 | Expense |
Set up this UDC to specify the ISO country code in the Description 02 column required for SAF-T reporting. You need to specify this if the ISO country code is different from the country code available in the Country Codes (00/CN) UDC table.
Set up this UDC to specify the tax country region in the Description 02 column required for SAF-T reporting.
Localizations Additional Information is a tag-table methodology that captures and stores country-specific information. The system uses this information for different purposes.
Before you can start working with Localizations Additional Information, you must run the Additional Info Setup program (R7000100) to generate the required tables that store the additional data.
This setup also generates the forms where you enter predefined information that is saved to the Localizations Additional Fields tables.
The system launches the Localizations Additional Information forms from the Regional Info row menu option from the specific programs that require additional data.
When you run the Additional Information Setup program, the system also generates all the additional fields required in the appropriate Regional Info forms. The forms for Localizations Additional Information group the predefined data fields into the following tabs, according to the type of data that you enter:
String Data: You enter a set of alphanumeric characters.
Numeric Data: You enter a set of numeric characters.
Date: You enter a date.
Character: You enter single characters.
Every time you run the Additional Information Setup program, the system regenerates the tables required to work with the solution. You do not need to run this program multiple times but if you do, the existing data that you entered and that is saved in the Additional Information tables is not affected.
Before you complete the task in this section:
Verify that the Localization Country Code field in your user profile is set up. For example, NO for Norway or AT for Austria.
Set up the following processing option for the Additional Info Setup Program (R7000100):
Code - Localization Country: Select a value from the Localization Country Code UDC table (00/LC) to specify the country for which the system generates the Additional Information tables and forms.
Select System Administration Tools (GH9011), Batch Versions.
Alternatively, enter BV in the Fast Path field.
In the Work With Batch Versions - Available Versions form, enter R7000100 in the Batch Application field to work with the Additional Info Setup program.
You generate the OECD SAF-T Generic Extractor Report to get an intermediate XML file.
Before you generate the OECD SAF-T Generic Extractor report:
Verify that the localization country code is set up for the country for which you want to generate the SAF-T report.
Run the Additional Info Setup program (R7000100) to generate the required tables that store the additional data.
Verify that the invoice number is available for the purchase transactions.
Verify that the original document information of credit note and debit note is available in the reference column of the Customer Ledger table (F03B11) and the Accounts Payable Ledger table (F0411).
Verify that the transaction is posted. The report does not consider void transactions.
Run the As Of Regeneration program (R41542) to ensure that the item stock quantity balance forwards are restored for each fiscal year.
SeeE1: 41: As Of Processing (P4111 / P41112 / R41760 / R41540 / R41542) (Doc ID 625402.1)
Set up processing options for the R705001 report. For more information.
See Section 1.4.2, "Setting Processing Options for the OECD SAF-T Generic Extractor Report (R705001)".
Set up the additional information for the Address Book (P01012), Tax Rate/Areas (P4008), and Account Masters (P0901) programs. For more information.
Before you generate the SAF-T report, you set the processing options for the OECD SAF-T Generic Extractor report (R705001):
Use this option to specify the code that identifies a specific organization, fund, or other reporting entity. The company code must exist in the Company Constants table (F0010). This processing option must not be blank.
Use this option to specify the start of the fiscal year and the accounting period for which the system generates the SAF-T report.
Use this option to specify the end of the fiscal year and the accounting period for which the system generates the SAF-T report.
The start of the fiscal year value in the From processing option should be earlier than the end of the fiscal year value in the To processing option.
Specify the audit file version of the XML schema that is used for SAF-T reporting.
Specify the code that identifies the country for which the system generates the SAF-T report. The value that you enter must exist in the Country Codes (00/CN) UDC table.
Company's International Bank Account Number
Either company bank account or IBAN should be available to generate the report.
The value that you enter must exist in the Ledger Types (09/LT) UDC.
The value that you enter must exist in the Cost Method (40/CM) UDC.
Before you generate the SAF-T report, you must set up the additional information for following programs:
Accounts Master (P0901)
Set the following additional information of the Address Book Additional Information program (P700101A):
Self Billing Indicator: Specify the self-billing indicator to identify the existence of a self-billing agreement between the customer and the supplier.
Set the following additional information of the Work with Tax Area Additional Information program (P704008A):
String Data
Tax Exemption Reason: Specify the tax exemption reason associated with the tax rate or tax area. The value that you enter must exist in the Tax Exemption Reasons (70/ER) UDC table.
Tax Type: Specify the tax type for the record. The value that you enter must exist in the Tax Type (70/TT) UDC table.
Tax Country Region: Specify the classified tax region of the country. The value that you enter must exist in the State & Province Codes (00/S) UDC table.
Tax Code: Specify the tax code for the record required by the tax authorities. The value that you enter must exist in the Tax Code (70/TC) UDC table.
Country: Specify the country code to apply the Tax Rate/Area. The value that you enter must exist in the Country Code (00/CN) UDC table.
Tax Exempt: Specify the code indicating whether the tax rate or tax area is tax exempt or taxable. If it is tax-exempt, provide the reason for the exemption. The value that you enter must exist in the Tax Exempt (70/TE) UDC table.
Set the following additional information of the Work with Account Master Additional Information program (P700901A):
String Data
Standard Account ID: Specify the account ID based on the standard prescribed by the authorities.
Account Type: Specify the account type–that is, asset, liability, sale, or expense. The value that you enter must exist in the Account Type (70/AT) UDC table.
To generate the OECD SAF-T Generic Extractor Report, from the OECD SAFT Generic Reporting (G7006) menu, select OECD SAF-T Generic Extractor Report (R705001). When you run the OECD SAF-T Generic Extractor report, the system validates and generates the SAFT XML file.
The JD Edwards EnterpriseOne system populates various sections of the OECD SAF-T report:
Header Section
The header section of the OECD SAF-T report includes company information, audit file information, information about the software company producing the file, and the selection criteria.
Master Files Section
The master files section includes:
| Master File Sections | Description |
| General Ledger Accounts | This section prints the general ledger accounts details. The R705001 report identifies the transactions from the General Ledger Entries section to print the required details. |
| Customers | This section prints the required details related to the customer. The R705001 report identifies customer-related information from the Source Documents section and the General Ledger Entries section. |
| Supplier | This section prints the required details related to the supplier. The R705001 report identifies supplier-related information from the Source Documents section and the General Ledger Entries section. |
| Tax Table | The R705001 identifies the tax area or tax rate from the Source Documents section and the General Ledger Entries section, and retrieves information from the Work with Tax Area Additional Information program (P704008A) to print the details. |
| UOM Table | This section prints the UOM details. The R705001 report identifies item-related information from the Source Documents section. |
| Movement Type Table | This section prints the movement type details. The R705001 report identifies the transactions from the Movement of Goods section. |
| Products | This section prints the product details. The R705001 report identifies item-related information from the Source Documents section. |
| Owners | The R705001 report identifies company-related information from the processing option to print the details. |
| Physical Stock | This section prints the physical stock details. The R705001 report identifies item-related information from the Source Documents section to print the physical stock details.
You must set up unit price in primary Unit of Measure (UOM) in the Cost Revisions program (P4105). |
The general ledger entries section lists the journal entries for the selected period. The R075001 report identifies the posted transactions from the Account Ledger table (F0911) to print the journal entry details.
The system prints the tax information of the transaction if the transaction is created using the Journal Entries with VAT program (P09106).
Source Documents Section
The source documents section includes:
| Source Documents Section | Description |
| Sales Invoices | This section prints the Sales and A/R transactions. The report retrieves the posted and non-void transactions from the Customer Ledger table (F03B11). The system considers a transaction line in the F03B11 table for printing sales order details if the Document Company (PKCO), Document No (DOCO), Document type (DCTO), and Line ID (LNID) fields are populated. |
| Purchase Invoices | This section prints the purchase and A/P transactions. The report retrieves the posted and non-void transactions from the Accounts Payable Ledger table (F0411). The system considers a transaction line in the F0411 table for printing purchase invoices details if the Document Company (KCOO), Document No (DOCO), Document type (DCTO), and Line ID (LNID) fields are populated. |
| Payments | This section prints the payment details of the posted and non-void transactions. The R075001 report retrieves the posted and non-void transactions from the Accounts Payable Matching Document Detail table (F0414) and the Receipts Header table (F03B13). |
| Movement of Goods | This section prints the movement of goods details of the transactions. The R075001 report retrieves the transactions from the Sales Order Detail table (F4211) or the Sales History table (F42119), and the Purchase Order Receiver table (F43121) to print movement of goods details.
You must confirm shipment and complete the sales update process to include the sales transactions in the report. You must complete the voucher match process and purchase order receipt to include the purchase transactions in the report. See ”Shipment Planning” in the JD Edwards EnterpriseOne Applications Transportation Management Implementation Guide to know the process of generating shipment number. |
Notes:
