Release 4.1: st_flushcommit
The DB_ENV->log_stat "st_flushcommits" statistic has been removed from Berkeley DB, as it is now the same as the "st_scount" statistic. Any application using the "st_flushcommits" statistic should remove it, or replace it with the "st_count" statistic.
