Deleting records
The DB->del() method deletes records from the database. In general, DB->del() takes a key and deletes the data item associated with it from the database.
If the database has been configured to support duplicate records, the DB->del() method will remove all of the duplicate records. To remove individual duplicate records, you must use a Berkeley DB cursor interface.
