There are a few different issues to consider when tuning the
performance of Berkeley DB access method applications.
access method
An application's choice of a database access
method can significantly affect performance.
Applications using fixed-length records and integer
keys are likely to get better performance from the
Queue access method. Applications using
variable-length records are likely to get better
performance from the Btree access method, as it tends
to be faster for most applications than either the
Hash or Recno access methods. Because the access
method APIs are largely identical between the Berkeley
DB access methods, it is easy for applications to
benchmark the different access methods against each
other. See Selecting an access method for more
information.
cache size
The Berkeley DB database cache defaults to a
fairly small size, and most applications concerned
with performance will want to set it explicitly. Using
a too-small cache will result in horrible performance.
The first step in tuning the cache size is to use the
db_stat utility (or the statistics returned by the
DB->stat() function) to measure the effectiveness of the
cache. The goal is to maximize the cache's hit rate.
Typically, increasing the size of the cache until the
hit rate reaches 100% or levels off will yield the
best performance. However, if your working set is
sufficiently large, you will be limited by the
system's available physical memory. Depending on the
virtual memory and file system buffering policies of
your system, and the requirements of other
applications, the maximum cache size will be some
amount smaller than the size of physical memory. If
you find that the db_stat utility shows that increasing the
cache size improves your hit rate, but performance is
not improving (or is getting worse), then it's likely
you've hit other system limitations. At this point,
you should review the system's swapping/paging
activity and limit the size of the cache to the
maximum size possible without triggering paging
activity. Finally, always remember to make your
measurements under conditions as close as possible to
the conditions your deployed application will run
under, and to test your final choices under worst-case
conditions.
shared memory
By default, Berkeley DB creates its database
environment shared regions in filesystem backed
memory. Some systems do not distinguish between
regular filesystem pages and memory-mapped pages
backed by the filesystem, when selecting dirty pages
to be flushed back to disk. For this reason, dirtying
pages in the Berkeley DB cache may cause intense
filesystem activity, typically when the filesystem
sync thread or process is run. In some cases, this can
dramatically affect application throughput. The
workaround to this problem is to create the shared
regions in system shared memory (DB_SYSTEM_MEM) or
application private memory (DB_PRIVATE), or, in
cases where this behavior is configurable, to turn off
the operating system's flushing of memory-mapped
pages.
large key/data items
Storing large key/data items in a database can
alter the performance characteristics of Btree, Hash
and Recno databases. The first parameter to consider
is the database page size. When a key/data item is too
large to be placed on a database page, it is stored on
"overflow" pages that are maintained outside of the
normal database structure (typically, items that are
larger than one-quarter of the page size are deemed to
be too large). Accessing these overflow pages requires
at least one additional page reference over a normal
access, so it is usually better to increase the page
size than to create a database with a large number of
overflow pages. Use the db_stat utility (or the statistics
returned by the DB->stat() method) to review the number
of overflow pages in the database.
The second
issue is using large key/data items instead of
duplicate data items. While this can offer
performance gains to some applications (because it
is possible to retrieve several data items in a
single get call), once the key/data items are
large enough to be pushed off-page, they will slow
the application down. Using duplicate data items
is usually the better choice in the long
run.
A common question when tuning Berkeley DB applications is
scalability. For example, people will ask why, when adding
additional threads or processes to an application, the overall
database throughput decreases, even when all of the operations
are read-only queries.
First, while read-only operations are logically concurrent,
they still have to acquire mutexes on internal Berkeley DB
data structures. For example, when searching a linked list and
looking for a database page, the linked list has to be locked
against other threads of control attempting to add or remove
pages from the linked list. The more threads of control you
add, the more contention there will be for those shared data
structure resources.
Second, once contention starts happening, applications will
also start to see threads of control convoy behind locks
(especially on architectures supporting only test-and-set spin
mutexes, rather than blocking mutexes). On test-and-set
architectures, threads of control waiting for locks must
attempt to acquire the mutex, sleep, check the mutex again,
and so on. Each failed check of the mutex and subsequent sleep
wastes CPU and decreases the overall throughput of the
system.
Third, every time a thread acquires a shared mutex, it has
to shoot down other references to that memory in every other
CPU on the system. Many modern snoopy cache architectures have
slow shoot down characteristics.
Fourth, schedulers don't care what application-specific
mutexes a thread of control might hold when de-scheduling a
thread. If a thread of control is descheduled while holding a
shared data structure mutex, other threads of control will be
blocked until the scheduler decides to run the blocking thread
of control again. The more threads of control that are
running, the smaller their quanta of CPU time, and the more
likely they will be descheduled while holding a Berkeley DB
mutex.
The results of adding new threads of control to an
application, on the application's throughput, is application
and hardware specific and almost entirely dependent on the
application's data access pattern and hardware. In general,
using operating systems that support blocking mutexes will
often make a tremendous difference, and limiting threads of
control to to some small multiple of the number of CPUs is
usually the right choice to make.
