Sun Management Center 3.6 User's Guide
ProcedureTo See When an Alarm Ended or Was Acknowledged
Steps
  1. From the Host Details Alarms page, click the first column of the alarm that you want to view.
    A check mark is displayed in the first column.
    Note –
    You can view additional information only for one alarm at a time.
  2. Choose Additional Alarm Information from the Options menu, and click the Go button.
    The Additional Alarm Information section at the bottom of the page updates with appropriate information, if applicable.
    • If the alarm has been acknowledged, the Alarm Acknowledged field indicates who acknowledged the alarm. This field also tells you when the alarm was acknowledged.
    • If the alarm has ended, the Alarm Ended field indicates when the alarm ended.
