Name | Synopsis | Description | Options | Exit Status | Attributes | See Also
/usr/lib/inet/wanboot/p12split -i p12file -c out_cert -k out_key
[-t out_trust -l id -v]
The p12split utility extracts a certificate and private key from the repository specified by p12file, depositing the certificate in out_cert and the key in out_key. If supplied, the -l option specifies the value for the LocalKeyId that will be used in the new certificate and key files. p12split can optionally extract a trust certificate into the out_trust file if the -t option is specified. Use the -v option to get a verbose description of the split displayed to standard output.
The following arguments and options are supported:
Specifies a repository that receives a extracted certificate.
Specifies a repository from which a certificate and private key is extracted.
Specifies a repository that receives a extracted private key.
Specifies the value for the LocalKeyId that will be used in the new certificate and key files.
Specifies a file for receiving an extracted trust certificate.
Displays a verbose description of the split to stdout.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWwbsup |
Interface Stability |
Unstable |
