Name | Synopsis | Description | Return Values | Errors | Attributes | See Also
cc [ flag... ] file... –lrsm [ library... ] #include <rsmapi.h> int rsm_intr_signal_post(void *memseg, uint_t flags);
int rsm_intr_signal_wait(void *memseg, int timeout);
The rsm_intr_signal_post() and rsm_intr_signal_wait() functions are event functions that allow synchronization between importer processes and exporter processes. A process may block to wait for an event occurance by calling rsm_intr_signal_wait(). A process can signal a waiting process when an event occurs by calling rsm_intr_signal_post().
The rsm_intr_signal_post() function signals an event occurance. Either an import segment handle (rsm_memseg_import_handle_t) or an export segment handle (rsm_memseg_export_handle_t) may be type cast to a void pointer for the memseg argument. If memseg refers to an import handle, the exporting process is signalled. If memseg refers to an export handle, all importers of that segment are signalled. The flags argument may be set to RSM_SIGPOST_NO_ACCUMULATE; this will cause this event to be discarded if an event is already pending for the target segment.
The rsm_intr_signal_wait() function allows a process to block and wait for an event occurance. Either an import segment handle (rsm_memseg_import_handle_t) or an export segment handle (rsm_memseg_export_handle_t) may be type cast to a void pointer for the memseg argument. The process blocks for up to timeout milliseconds for an event to occur; if the timeout value is -1, the process blocks until an event occurs or until interrupted.
Upon successful completion, these functions return 0. Otherwise, an error value is returned to indicate the error.
The rsm_intr_signal_post() and rsm_intr_signal_wait() functions can return the following error:
Invalid segment handle.
The rsm_intr_signal_post() function can return the following error:
Connection aborted.
Remote node not reachable.
The rsm_intr_signal_wait() function can return the following errors:
Wait interrupted.
Timer expired.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Interface Stability |
Evolving |
MT-Level |
MT-Safe |
