Name | Synopsis | Description | Parameters | Return Values | Attributes | See Also
cc [ flag... ] file... -lmlib [ library... ] #include <mlib.h> mlib_status mlib_ImageComposite(mlib_image *dst, const mlib_image *src1, const mlib_image *src2, mlib_blend bsrc1, mlib_blend bsrc2, mlib_s32 cmask);
The mlib_ImageComposite() function supports digital image composition.
It is a wrapper of the mlib_ImageBlend_BSCR1_BSRC2 group of functions and can perform various types of composition based on the parameters passed in, whereas each function in that group can perform only the one kind of composition denoted by its name.
The image type must be MLIB_BYTE. The input and output images must contain three or four channels. For three-channel images, the alpha value is as if the alpha value is 1.
The following are predefined blend factor types used in mediaLib image composition functions.
/* image blend factors */ typedef enum { MLIB_BLEND_ZERO, MLIB_BLEND_ONE, MLIB_BLEND_DST_COLOR, MLIB_BLEND_SRC_COLOR, MLIB_BLEND_ONE_MINUS_DST_COLOR, MLIB_BLEND_ONE_MINUS_SRC_COLOR, MLIB_BLEND_DST_ALPHA, MLIB_BLEND_SRC_ALPHA, MLIB_BLEND_ONE_MINUS_DST_ALPHA, MLIB_BLEND_ONE_MINUS_SRC_ALPHA, MLIB_BLEND_SRC_ALPHA_SATURATE } mlib_blend;
See the following table for the definitions of the blend factors.
Type |
Blend Factor [*] |
Abbr. |
MLIB_BLEND_ZERO |
(0,0,0,0) |
ZERO |
MLIB_BLEND_ONE |
(1,1,1,1) |
ONE |
MLIB_BLEND_DST_COLOR |
(Rd,Gd,Bd,Ad) |
DC |
MLIB_BLEND_SRC_COLOR |
(Rs,Gs,Bs,As) |
SC |
MLIB_BLEND_ONE_MINUS_DST_COLOR |
(1,1,1,1)-(Rd,Gd,Bd,Ad) |
OMDC |
MLIB_BLEND_ONE_MINUS_SRC_COLOR |
(1,1,1,1)-(Rs,Gs,Bs,As) |
OMSC |
MLIB_BLEND_DST_ALPHA |
(Ad,Ad,Ad,Ad) |
DA |
MLIB_BLEND_SRC_ALPHA |
(As,As,As,As) |
SA |
MLIB_BLEND_ONE_MINUS_DST_ALPHA |
(1,1,1,1)-(Ad,Ad,Ad,Ad) |
OMDA |
MLIB_BLEND_ONE_MINUS_SRC_ALPHA |
(1,1,1,1)-(As,As,As,As) |
OMSA |
MLIB_BLEND_SRC_ALPHA_SATURATE |
(f,f,f,1) |
SAS |
[*]: The components of the first source image pixel are (Rd,Gd,Bd,Ad), and the components of the second source pixel are (Rs,Gs,Bs,As). Function f = min(As, 1-Ad).
The blending formula for non-in-place processing is:
Cd = Cs1*S1 + Cs2*S2
where Cd is the destination pixel (Rd,Gd,Bd,Ad), Cs1 is the first source pixel (Rs1,Gs1,Bs1,As1), Cs2 is the second source pixel (Rs2,Gs2,Bs2,As2), and S1 and S2 are the blend factors for the first and second sources, respectively.
The function takes the following arguments:
Pointer to destination image.
Pointer to the first source image.
Pointer to the second source image.
Blend factor type for the first source image.
Blend factor type for the second source image.
Channel mask to indicate the alpha channel. Each bit of the mask represents a channel in the image. The channel corresponding to the 1 bit is the alpha channel. cmask must be either 0x01 or 0x08.
The function returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Interface Stability |
Committed |
MT-Level |
MT-Safe |
mlib_ImageBlend_BSRC1_BSRC2(3MLIB), mlib_ImageBlend_BSRC1_BSRC2_Inp(3MLIB), mlib_ImageComposite_Inp(3MLIB), attributes(5)
