Name | Synopsis | Description | Parameters | Return Values | Attributes | See Also
cc [ flag... ] file... -lmlib [ library... ] #include <mlib.h> mlib_status mlib_ImageConstMulShift(mlib_image *dst, const mlib_image *src, const mlib_s32 *c, mlib_s32 shift);
The mlib_ImageConstMulShift() function multiplies each pixel in an image by a constant value on a pixel-by-pixel basis. It scales the result by a right shift and writes the result to the destination image on a pixel-by-pixel basis.
It uses the following equation:
dst[x][y][i] = c[i] * src[x][y][i] * 2**(-shift)
The function takes the following arguments:
Pointer to destination image.
Pointer to source image.
Constant by which each pixel is multiplied. c[i] contains the constant for channel i.
Right shifting factor. 0 ≤ shift ≤ 31.
The function returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Interface Stability |
Committed |
MT-Level |
MT-Safe |
mlib_ImageConstMul(3MLIB), mlib_ImageConstMul_Fp(3MLIB), mlib_ImageConstMul_Fp_Inp(3MLIB), mlib_ImageConstMul_Inp(3MLIB), mlib_ImageConstMulShift_Inp(3MLIB), attributes(5)
