Name | Synopsis | Description | Parameters | Return Values | Attributes | See Also
cc [ flag... ] file... -lmlib [ library... ] #include <mlib.h> mlib_status mlib_ImageThresh3_Fp(mlib_image *dst, const mlib_image *src, const mlib_d64 *thresh, const mlib_d64 *ghigh);
The mlib_ImageThresh3_Fp() function compares each pixel in the floating-point source image to a threshold value. If the pixel is less than or equal to the threshold value, then the destination pixel is set to the value of the source pixel. If the pixel is greater than the threshold value, then the destination pixel is set to the high output level.
It uses the following equation:
dst[x][y][i] = src[x][y][i] if src[x][y][i] ≤ thresh[i] dst[x][y][i] = ghigh[i] if src[x][y][i] > thresh[i]
The function takes the following arguments:
Pointer to destination image.
Pointer to source image.
Threshold value. thresh[i] contains the threshold for channel i.
High output level. ghigh[i] contains the high output level for channel i.
The function returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Interface Stability |
Committed |
MT-Level |
MT-Safe |
mlib_ImageThresh1(3MLIB), mlib_ImageThresh1_Fp(3MLIB), mlib_ImageThresh1_Fp_Inp(3MLIB), mlib_ImageThresh1_Inp(3MLIB), mlib_ImageThresh2(3MLIB), mlib_ImageThresh2_Fp(3MLIB), mlib_ImageThresh2_Fp_Inp(3MLIB), mlib_ImageThresh2_Inp(3MLIB), mlib_ImageThresh3(3MLIB), mlib_ImageThresh3_Fp_Inp(3MLIB), mlib_ImageThresh3_Inp(3MLIB), mlib_ImageThresh4(3MLIB), mlib_ImageThresh4_Fp(3MLIB), mlib_ImageThresh4_Fp_Inp(3MLIB), mlib_ImageThresh4_Inp(3MLIB), mlib_ImageThresh5(3MLIB), mlib_ImageThresh5_Fp(3MLIB), mlib_ImageThresh5_Fp_Inp(3MLIB), mlib_ImageThresh5_Inp(3MLIB), attributes(5)
