Name | Synopsis | Description | Parameters | Return Values | Attributes | See Also
cc [ flag... ] file... -lmlib [ library... ] #include <mlib.h> mlib_status mlib_SignalAutoCorrel_S16(mlib_d64 *correl, const mlib_s16 *src, mlib_s32 disp, mlib_s32 n);
mlib_status mlib_SignalAutoCorrel_S16S(mlib_d64 *correl, const mlib_s16 *src, mlib_s32 disp, mlib_s32 n);
mlib_status mlib_SignalAutoCorrel_F32(mlib_d64 *correl, const mlib_f32 *src, mlib_s32 disp, mlib_s32 n);
mlib_status mlib_SignalAutoCorrel_F32S(mlib_d64 *correl, const mlib_f32 *src, mlib_s32 disp, mlib_s32 n);
Each of these functions performs auto-correlation.
For monaural signals, the following equation is used:
1 n-d-1 correl[0] = ----- * SUM (src[i] * src[i + d]) n - d i=0
For stereo signals, the following equation is used:
1 n-d-1 correl[0] = ----- * SUM (src[2*i] * src[2*(i + d)]) n - d i=0 1 n-d-1 correl[1] = ----- * SUM (src[2*i + 1] * src[2*(i + d) + 1]) n - d i=0
where d = disp.
Each of the functions takes the following arguments:
Pointer to the auto-correlation array. In the stereo version, correl[0] contains the auto-correlation of channel 0, and correl[1] contains the auto-correlation of channel 1.
Source signal array.
Displacement. 0 ≤ disp < n.
Number of samples in the source signal array.
Each of the functions returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Interface Stability |
Committed |
MT-Level |
MT-Safe |
