Name | Synopsis | Description | Parameters | Return Values | Attributes | See Also
cc [ flag... ] file... -lmlib [ library... ] #include <mlib.h> mlib_status mlib_SignalMulSAdd_S16_Sat(mlib_s16 *scr1dst, const mlib_s16 *src2, const mlib_s16 *c, mlib_s32 n);
mlib_status mlib_SignalMulSAdd_S16S_Sat(mlib_s16 *scr1dst, const mlib_s16 *src2, const mlib_s16 *c, mlib_s32 n);
Each of these functions performs multiplication by a scalar plus addition.
Each of the functions takes the following arguments:
The first input and the output signal array.
The second input signal array.
Scaling factor. The scaling factor is in Q15 format. In the stereo version; c[0] contains the scaling factor for channel 0, and c[1] holds the scaling factor for channel 1.
Number of samples in the input signal arrays.
Each of the functions returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Interface Stability |
Committed |
MT-Level |
MT-Safe |
