Name | Synopsis | Description | Parameters | Return Values | Attributes | See Also
cc [ flag... ] file... -lmlib [ library... ] #include <mlib.h> mlib_status mlib_VideoColorJFIFYCC2RGB420_Nearest(mlib_u8 *rgb0, mlib_u8 *rgb1, const mlib_u8 *y0, const mlib_u8 *y1, const mlib_u8 *cb, const mlib_u8 *cr, mlib_s32 n);
The mlib_VideoColorJFIFYCC2RGB420_Nearest() function performs color space conversion from YCbCr to RGB together with sampling rate conversion when used in the JPEG File Interchange Format (JFIF).
The function takes the following arguments:
Pointer to upper destination RGB multi-component row. rgb0 must be 8-byte aligned.
Pointer to lower destination RGB multi-component row. rgb1 must be 8-byte aligned.
Pointer to upper destination Y component row. y0 must be 8-byte aligned.
Pointer to lower destination Y component row. y1 must be 8-byte aligned.
Pointer to source Cb component row. cb must be 8-byte aligned.
Pointer to source Cr component row. cr must be 8-byte aligned.
Length of Y component row. n must be even. The length of Cb and Cr component rows must be n/2. The length of the RGB multi-component row must be 3*n.
The function returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Interface Stability |
Committed |
MT-Level |
MT-Safe |
mlib_VideoColorJFIFYCC2RGB420(3MLIB), mlib_VideoColorJFIFYCC2RGB422(3MLIB), mlib_VideoColorJFIFYCC2RGB422_Nearest(3MLIB), attributes(5)
