Name | Synopsis | Description | Parameters | Return Values | Attributes | See Also
cc [ flag... ] file... -lmlib [ library... ] #include <mlib.h> void mlib_VideoColorRGBseq_to_ABGRint(mlib_u32 *ABGR, const mlib_u8 *R, const mlib_u8 *G, const mlib_u8 *B, const mlib_u8 *A_array, mlib_u8 A_const, mlib_s32 w, mlib_s32 h, mlib_s32 dlb, mlib_s32 slb);
The R, G, and B streams, and the A values are combined into an A, B, G, R interleaved byte stream. Within each 32-bit output word, the component ordering is A (bits 31-24), B (bits 23-16), G (bits 15-8), and R (bits 7-0).
The alpha values for this function work in the following fashion:
If A_array pointer is not NULL, the values are taken from there. It has to have the same dimensions as the R, G, and B buffers.
If A_array pointer is NULL, the alpha values for every pixel are set to A_const.
The function takes the following arguments:
Pointer to output buffer.
Pointer to input R buffer.
Pointer to input G buffer.
Pointer to input B buffer.
Array of alpha values.
Constant alpha value.
Image width in pixels.
Image height in lines.
Linebytes for output buffer.
Linebytes for input buffers.
None.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Interface Stability |
Committed |
MT-Level |
MT-Safe |
mlib_VideoColorRGBint_to_ABGRint(3MLIB), mlib_VideoColorBGRint_to_ABGRint(3MLIB), mlib_VideoColorRGBXint_to_ABGRint(3MLIB), mlib_VideoColorRGBXint_to_ARGBint(3MLIB), mlib_VideoColorXRGBint_to_ABGRint(3MLIB), mlib_VideoColorXRGBint_to_ARGBint(3MLIB), attributes(5)
