Name | Synopsis | Description | Examples | Attributes | See Also
mmsclient_script
This man page describes the syntax of the script file that is driven by the mmsclient(1M) utility. This file contains a list of Media Management Protocol (MMP) commands that are used to communicate with a Media Management server.
The MMP and the commands in the script file are based, in part, on IEEE 1244, the Media Management System (MMS) standards.
In the script file, each MMP command must start with one of the following symbols as the first character:
Indicates the following characters document the file or command. Any character following the # character on the same line is ignored.
Indicates that the command on the next line is sent in async mode. Any character following the @ character on the same line is ignored. The MMP command to be performed must start on the next line. Commands that are not preceded with the @ character are sent in sync mode, that is, the mmsclient command waits for a response before continuing to the next MMP command in the file.
Forces the mmsclient command to wait for a response to a previous async command. For example, if the script contained an async command such as:
@task["Get volume Names"] |
...a subsequent command:
$Get volume Names |
...stops the script until the volume names are retrieved.
Displays a prompt on the display device and pauses the script. To respond to the prompt, type the requested information, ending with the semicolon (;) character. The mmsclient utility then sends the information to the MMS server. To skip the MMP prompt, type the q character.
The script stops until you press the Enter key.
The mmsclient utility issues a call to system(3C) to invoke a command. Whatever command follows ! is run in the shell in which mmsclient is run. For example:
! date |
See the shell commands in the example script below.
The following script, demo_example, demonstrates the special characters and some MMP commands. It is executed with default values when the command:
# mmsclient -f demo _example |
...is run.
#mmsclient example script #Send show commands in sync mode show task["sync show command 1"] report[DM] reportmode[namevalue] number[1..2]; show task["sync show command 2"] report[LM LIBRARY] reportmode[namevalue] number[1..2]; #Pause the script and wait for someone to #press Enter to continue % #send show commands in async mode @ show task["async show command 1"] report[DRIVE] reportmode[namevalue] number[1..2]; @ show task["async show command 2"] report[CARTRIDGE VOLUME] reportmode[namevalue] number[1..2]; #set a sync point for the second async command, #to stop the script until the response is complete $async show command 2 #set a sync point for an unsent command and set #a sync pont for a command that has already received a response. #mmsclient does not stop for either one $sync show command 1 #Start interactive MMP prompt. #To continue, enter an MMP command or 'q' > #Register for a some events notify task["notify test3"] receive[tag["client connected"] object[CONNECTION] action["add"] match[streq(CONNECTION."Language" "MMP")]] receive[tag["client disconnected"] object[CONNECTION] action["delete"] match[streq(CONNECTION."Language" "MMP")]] receive[tag["DM connected"] object[CONNECTION] action["add"] match[streq(CONNECTION."Language" "DMP")]] receive[tag["DM disconnected"] object[CONNECTION] action["delete"] match[streq(CONNECTION."Language" "DMP")]] receive[tag["LM connected"] object[CONNECTION] action["add"] match[streq(CONNECTION."Language" "LMP")]] receive[tag["LM disconnected"] object[CONNECTION] action["delete"] match[streq(CONNECTION."Language" "LMP")]] ; #Pause the script #Connect another mmsclient to see some events #Press Enter key to continue % notify task["delete all CONNECTION events"] cancel[object[CONNECTION]]; #Pause the script and wait. #Connect another mmsclient to verify the events are cancelled. #Press Enter key to continue % #Execute some simple shell commands !echo Hello World !uname -a !hostname #Pause the script and wait. #Press Enter key to continue % #Send last command in async mode. #mmsclient does not exit until it receives the responses #for all pending commmands. @ show task["async show command 3"] report[APPLICATION] reportmode[namevalue]; @ show task["async show command 4"] report[AI] reportmode[namevalue]; |
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWmmsu |
Interface Stability |
Volatile |
mmsadm(1M), mmsclient(1M), mmsexplorer(1M), mmsinit(1M), system(3C), attributes(5)
IEEE 1244, IEEE Storage Systems Standards, a set of MMS standards
