Name | Description | Device Special Files | ioctls | Errors | Files | Attributes | See Also
The blk2scsa module provides support services for generic block devices so that they appear to the system as devices on a virtual SCSI bus, thus allowing them to be serviced by the sd(7D) SCSI disk driver. The blk2scsa device supports the SCSI-2 command set for Direct Access Devices. The blk2scsa device supports multiple LUNs per physical device and creates a separate child device for each LUN. All child nodes attach to sd(7D).
Disk block special file names are located in /dev/dsk. Raw file names are located in /dev/rdsk. See sd(7D).
See dkio(7I)
See sd(7D).
Device special files for the storage device are created in the same way as those for a SCSI disk. See sd(7D) for more information.
Block files for disks.
Raw files for disks.
32-bit ELF kernel module (x86).
64-bit ELF kernel module (x86).
64-bit ELF kernel module (SPARC).
See attributes(5) for a description of the following attributes:
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Architecture |
SPARC, x86 |
Availability |
SUNWckr |
eject(1), rmformat(1), rmmount(1), cfgadm_scsi(1M), fdisk(1M), mount(1M), umount(1M), scsi(4), vfstab(4), attributes(5), sd(7D), dkio(7I), pcfs(7FS)
