Name | Synopsis | Description | CONFIGURATION | Examples | Files | Attributes | See Also | Diagnostics | Warnings | Notes
esp@sbus-slot,80000
The esp Host Bus Adapter driver is a SCSA compliant nexus driver that supports the Emulex family of esp SCSI chips (esp100, esp100A, esp236, fas101, fas236).
The esp driver supports the standard functions provided by the SCSA interface. The driver supports tagged and untagged queuing, fast SCSI (on FAS esp's only), almost unlimited transfer size (using a moving DVMA window approach), and auto request sense; but it does not support linked commands.
The esp driver can be configured by defining properties in esp.conf which override the global SCSI settings. Supported properties are: scsi-options, target<n>-scsi-options, scsi-reset-delay, scsi-watchdog-tick, scsi-tag-age-limit, scsi-initiator-id.
target<n>-scsi-options overrides the scsi-options property value for target<n>. <n> can vary from 0 to 7.
Refer to scsi_hba_attach(9F) for details.
scsi-options=0x78;
This will disable tagged queuing, fast SCSI, and Wide mode for all esp instances. To disable an option for one specific esp (refer to driver.conf(4)):
name="esp"
parent="/iommu@f,e0000000/sbus@f,e0001000/espdma@f,400000"
reg=0xf,0x800000,0x40
target1-scsi-options=0x58
scsi-options=0x178 scsi-initiator-id=6;
Note that the default initiator ID in OBP is 7 and that the change to ID 6 will occur at attach time. It may be preferable to change the initiator ID in OBP.
The above would set scsi-options for target 1 to 0x58 and for all other targets on this SCSI bus to 0x178. The physical pathname of the parent can be determined using the /devices tree or following the link of the logical device name:
example# ls -l /dev/rdsk/c0t3d0s0
lrwxrwxrwx 1 root root 88 Aug 22 13:29 /dev/rdsk/c0t3d0s0 ->
../../devices/iommu@f,e0000000/sbus@f,e0001000/espdma@f,400000/
esp@f,800000/sd@3,0:a,raw
The register property values can be determined from prtconf(1M) output (-v option):
esp, instance #0
Register Specifications:
Bus Type=0xf, Address=0x800000, Size=40
To set scsi-options more specifically per target:
target1-scsi-options=0x78;
device-type-scsi-options-list =
"SEAGATE ST32550W", "seagate-scsi-options" ;
seagate-scsi-options = 0x58;
scsi-options=0x3f8;
The above would set scsi-options for target 1 to 0x78 and for all other targets on this SCSI bus to 0x378 except for one specific disk type which will have scsi-options set to 0x58.
scsi-options specified per target ID has the highest precedence, followed by scsi-options per device type. To get the inquiry string run probe-scsi or probe-scsi-all command at the ok prompt before booting the system.
Global, for example. for all esp instances, scsi-options per bus has the lowest precedence.
The system needs to be rebooted before the specified scsi-options take effect.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Architecture |
SBus-based systems with esp-based |
SCSI port and SSHA, SBE/S, FSBE/S, |
and DSBE/S SBus SCSI Host Adapter options |
prtconf(1M), driver.conf(4), attributes(5), fas(7D), scsi_abort(9F), scsi_hba_attach(9F), scsi_ifgetcap(9F), scsi_reset(9F), scsi_sync_pkt(9F), scsi_transport(9F), scsi_device(9S), scsi_extended_sense(9S), scsi_inquiry(9S), scsi_pkt(9S)
OpenBoot Command Reference
ANSI Small Computer System Interface-2 (SCSI-2)
ESP Technical Manuals, QLogic Corp.
The messages described below are some that may appear on the system console, as well as being logged.
The first four messages may be displayed while the esp driver is trying to attach; these messages mean that the esp driver was unable to attach. All of these messages are preceded by "esp%d", where "%d" is the instance number of the esp controller.
The SBus device has been placed in a slave-only slot and will not be accessible; move to non-slave-only SBus slot.
The device was configured with an interrupt level that cannot be used with this esp driver. Check the SBus device.
Driver was unable to map device registers; check for bad hardware. Driver did not attach to device; SCSI devices will be inaccessible.
Driver was unable to locate a dma controller. This is an auto-configuration error.
Tagged queuing was disabled because disconnects were disabled in scsi-options.
Check for bad hardware.
Syncing a SCSI packet failed. Refer to scsi_sync_pkt(9F).
The driver could not allocate another tag number. The target devices do not properly support tagged queuing.
The driver could not allocate space for tag queue.
The driver experienced severe SCSI bus problems. Check cables and terminator.
The driver received an interrupt while the hardware was not interrupting.
The driver is confused about the state of the SCSI bus.
The DMA controller experienced host SBus problems. Check for bad hardware.
The esp hardware reported a bad sequence step. Check for bad hardware.
The selection of a target failed unexpectedly. Check for bad hardware.
Two targets selected simultaneously, which is illegal. Check for bad hardware.
A reconnect by a target failed. Check for bad hardware.
Suspect target f/w failure in tagged queue handling.
A parity error was detected in a tag message. Suspect SCSI bus problems.
The target supplied bad tag messages. Suspect target f/w failure in tagged queue handling.
The reconnect failed because of parity errors.
The target unexpectedly did not disconnect after sending <message>.
The esp driver can only transfer contiguous data.
Moving the DVMA window failed unexpectedly.
An attempt was made to cross a boundary that the driver could not handle.
The target went into an unexpected phase.
The driver detected parity errors on the SCSI bus.
An extended SCSI bus message did not complete. Suspect a target f/w problem.
A multibyte input message was truncated. Suspect a target f/w problem.
The driver is confused about messages coming from the target.
The extended message sent by the target is longer than expected.
Target <m> sent message <name> of value <n> which the driver did not understand.
Target <n> rejected a message sent by the driver.
The driver rejected a message received from target <n>
The driver was unable to send out command bytes.
The target did not accept a message resend.
The driver does not accept this two-byte message.
An attempt was made to select this host adapter by another initiator.
A polled command failed because the target did not complete outstanding commands within a reasonable time.
A polled command failed because of timeouts or bus errors.
A timeout occurred while target/lun was disconnected. This is usually a target f/w problem. For tagged queuing targets, <n> commands were outstanding when the timeout was detected.
This is usually a SCSI bus problem. Check cables and termination.
A data transfer hang was detected. The driver attempts to eliminate this problem by reducing the data transfer rate.
An attempt to reset the SCSI bus failed.
Another initiator reset the SCSI bus.
The esp hardware does not support Wide SCSI mode. Only FAS-type esp's support fast SCSI (10 MB/sec).
The esp driver exports properties indicating per target the negotiated transfer speed (target<n>-sync-speed) and whether tagged queuing has been enabled (target<n>-TQ). The sync-speed property value is the data transfer rate in KB/sec. The target-TQ property has no value. The existence of the property indicates that tagged queuing has been enabled. Refer to prtconf(1M) (verbose option) for viewing the esp properties.
dma, instance #3
Bus Type=0x2, Address=0x81000, Size=10
esp, instance #3
Driver software properties:
name <target3-TQ> length <0> - <no
value>.
name <target3-sync-speed> length <4>
value <0x00002710>.
name <scsi-options> length <4>
value <0x000003f8>.
name <scsi-watchdog-tick> length <4>
value <0x0000000a>.
name <scsi-tag-age-limit> length <4>
value <0x00000008>.
name <scsi-reset-delay> length <4>
value <0x00000bb8>.
SunOS 5.11 Last Revised 7 Feb 1997Name | Synopsis | Description | CONFIGURATION | Examples | Files | Attributes | See Also | Diagnostics | Warnings | Notes
