Name | Synopsis | Description | Files | Attributes | See Also
hwa-radio@unit-address
The hwarc driver is a USBA (Solaris USB Architecture) compliant client driver that supports Host Wire Adapter Radio Controller, specified in Wireless Universal Serial Bus Specification, Version 1.0.
The hwarc driver handles the Radio Controller Interface of an HWA device and properly controls the UWB (Ultra Wideband) Radio in the device. The driver controls an HWA device to Scan, Start/Stop Beacon, Get IE, and so forth.
32-bit ELF 86 kernel module
64-bit SPARC ELF kernel module
64-bit x86 ELF kernel module
See attributes(5) for a description of the following attributes:
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Architecture |
SPARC, x86 |
Availability |
SUNWusb |
add_drv(1M), prtconf(1M), rem_drv(1M), update_drv(1M), attributes(5), hwahc(7D), usba(7D), uwba(7D),
Universal Serial Bus Specification 1.0, 1.1 and 2.0 - 1996, 1998, 2000
Wireless Universal Serial Bus Specification 1.0
