Name | Description | DRIVER CONFIGURATION | Attributes | Files | See Also
The lsimega SCSI RAID host bus adapter driver is a SCSA-compliant nexus driver that supports LSI MegaRAID 320-2x SCSI RAID devices. The driver also supports LSI MegaRAID 320-1, 320-2e, Dell PERC 4e/Si, 4e/Di, 4e/DC RAID controllers.
The lsimega driver supports standard functions provided by the SCSA interface, including RAID disk I/O and passthrough I/O to support SCSI tape and CDROM.
The lsimega.conf file contains no user configurable parameters. Please configure your hardware through BIOS.
The LSI MegaRAID 320-2x device can support up to 40 logic drivers. Note that BIOS numbers the logic drives as 1 through 40, however in Solaris these drives are numbered from 0 to 39.
See attributes(5) for a description of the following attributes:
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
x86 |
32-bit ELF kernel module.
64–bit kernel module (x86 only).
Driver configuration file (contains no user-configurable options).
prtconf(1M), attributes(5), amr(7D), scsi_hba_attach_setup(9F), scsi_sync_pkt(9F), scsi_transport(9F), scsi_inquiry(9S), scsi_device(9S), scsi_pkt(9S)
Small Computer System Interface-2 (SCSI-2)
