Name | Synopsis | Description | Files | Attributes | See Also | Diagnostics
pcivid,pid@unit-address
The uhci host controller driver is a USBA (Solaris USB Architecture) compliant nexus driver that supports the Universal Host Controller Interface Specification 1.1, an industry standard developed by Intel. The uhci driver supports all USB transfers, including interrupt, control, isochronous and bulk.
32–bit ELF kernel module. (SPARC or x86).
64–bit ELF kernel module. (x86).
64-bit SPARC ELF kernel module.
Driver configuration file.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Architecture |
SPARC or x86 PCI-based systems |
Availability |
SUNWusb |
attributes(5), ehci(7D), hubd(7D), ohci(7D), usba(7D)
Writing Device Drivers
Universal Host Controller Interface Specification for USB 1.1
Universal Serial Bus Specification 2.0
System Administration Guide: Basic Administration
http://www.sun.com/io
All host controller errors are passed to the client drivers. Root errors are documented in hubd(7D).
In addition to being logged, the following messages may appear on the system console. All messages are formatted in the following manner:
WARNING: <device path> <uhci><instance number>>: Error message... |
The USB hardware is not generating Start Of Frame interrupts. Please reboot the system. If this problem persists, contact your system vendor.
