Name | Description | Files | Attributes | See Also | Diagnostics | Notes
The usb_ah STREAMS module enables the USB input control device which is a member of the Human Interface Device (HID) class and provides support for volume change and mute button. The usb_ah module is pushed on top of a HID class driver instance (see hid(7D)) and below an Audio Control class driver instance (see usb_ac(7D)). It translates the HID specific events to the events that are supported by the Solaris audio mixer framework.
32-bit ELF kernel STREAMS module. (x86 platform only.)
SPARC 64-bit ELF kernel STREAMS module
x8664-bit ELF kernel STREAMS module
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Architecture |
PCI-based systems |
Availability |
SUNWusb |
Interface Stability |
Committed |
hid(7D), usba(7D), usb_ac(7D), usb_as(7D), usb_mid(7D), audio(7I),
STREAMS Programming Guide
System Administration Guide: Basic Administration
Universal Serial Bus Specification 1.0 and 1.1
Device Class Definition for Human Interface Devices (HID) 1.1
None
If USB audio drivers are not loaded, buttons are not active.
