Name | Synopsis | Interface Level | Parameters | Description | Return Values | Context | Examples | Attributes | See Also
#include <sys/usb/usba.h> int usb_handle_remote_wakeup(dev_info_t *dip, int cmd);
Solaris DDI specific (Solaris DDI)
Pointer to the device's dev_info structure.
Command. Either USB_REMOTE_WAKEUP_ENABLE or USB_REMOTE_WAKEUP_DISABLE.
The usb_handle_remote_wakeup() function enables or disables remote wakeup on a USB device. This call can block.
Remote wakeup is successfully enabled or disabled.
Remote wakeup is not supported by the device. An internal error occurred.
May be called from user or kernel context.
uint_t *pwrstates;
/* Hook into device's power management. Enable remote wakeup. */
if (usb_create_pm_components(dip, pwrstates) == USB_SUCCESS) {
usb_handle_remote_wakeup(dip, USB_REMOTE_WAKEUP_ENABLE);
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Architecture |
PCI-based systems |
Interface stability |
Committed |
Availability |
SUNWusb |
attributes(5), pm_busy_component(9F), pm_idle_component(9F), pm_lower_power(9F), pm_raise_power(9F), usb_clr_feature(9F), usb_create_pm_components(9F), usb_get_cfg(9F), usb_get_dev_data(9F), usb_register_hotplug_cbs(9F), usb_cfg_descr(9S)
