System Administration Guide: IP Services
flowacct Records
A flowacct record contains the attributes described in the following table.
Table 31–4 Attributes of a flowacct Record
Attribute Name
Attribute Contents
Type
src-addr-address-type
Source address of the originator. address-type is either v4 for IPv4 or v6 for IPv6, as specified in the IPQoS configuration file.
Basic
dest-addr-address-type
Destination address for the packets. address-type is either v4 for IPv4 or v6 for IPv6, as specified in the IPQoS configuration file.
Basic
src-port
Source port from which the flow originated.
Basic
dest-port
Destination port number to which this flow is bound.
Basic
protocol
Protocol number for the flow.
Basic
total-packets
Number of packets in the flow.
Basic
total-bytes
Number of bytes in the flow.
Basic
action-name
Name of the flowacct action that recorded this flow.
Basic
creation-time
First time that a packet is seen for the flow by flowacct.
Extended only
last-seen
Last time that a packet of the flow was seen.
Extended only
diffserv-field
DSCP in the outgoing packet headers of the flow.
Extended only
user
Either a UNIX User ID or user name, which is obtained from the application.
Extended only
projid
Project ID, which is obtained from the application.
Extended only
