Once you determine the consumer of interest, you can retrieve the data corresponding to any unconsumed buffers by specifying the address of the state structure to the ::dtrace dcmd. The following example shows the output of the ::dtrace dcmd on an anonymous enabling of syscall:::entry with the action trace(execname):
> ::dtrace_state
ADDR MINOR PROC NAME FILE
cbfb7a40 2 - <anonymous> -
> cbfb7a40::dtrace
CPU ID FUNCTION:NAME
0 344 resolvepath:entry init
0 16 close:entry init
0 202 xstat:entry init
0 14 open:entry init
0 206 fxstat:entry init
0 186 mmap:entry init
0 190 munmap:entry init
0 216 memcntl:entry init
The ::dtrace dcmd handles errors in the same way that dtrace(1M) does: if drops, errors, speculative drops, or the like were encountered while the consumer was executing, ::dtrace will emit a message corresponding to the dtrace(1M)message.
The order of events as displayed by ::dtrace is always oldest to youngest within a given CPU. The CPU buffers themselves are displayed in numerical order. If an ordering is required for events on different CPUs, trace the timestamp variable.
You can display only the data for a specific CPU by specifying the -c option to ::dtrace:
> cbfb7a40::dtrace -c 1 CPU ID FUNCTION:NAME 1 14 open:entry init 1 206 fxstat:entry init 1 186 mmap:entry init 1 344 resolvepath:entry init 1 16 close:entry init 1 202 xstat:entry init 1 202 xstat:entry init 1 14 open:entry init 1 206 fxstat:entry init 1 186 mmap:entry init ... |
Notice that ::dtrace only processes in-kernel DTrace data. Data that has been consumed from the kernel and processed (through dtrace(1M) or other means) will not be available to be processed with ::dtrace. To assure that the most amount of data possible is available at the time of failure, use a ring buffer buffering policy. See Chapter 11, Buffers and Buffering for more information on buffer policies.
The following example creates a very small (16K) ring buffer and records all system calls and the process making them:
# dtrace -P syscall'{trace(curpsinfo->pr_psargs)}' -b 16k -x bufpolicy=ring
dtrace: description 'syscall:::entry' matched 214 probes
Looking at a crash dump taken when the above command was running results in output similar to the following example:
> ::dtrace_state
cdccd400 3 d15e80a0 dtrace ced065f0
> cdccd400::dtraceCPU ID FUNCTION:NAME
0 139 getmsg:return mibiisa -r -p 25216
0 138 getmsg:entry mibiisa -r -p 25216
0 17 close:return mibiisa -r -p 25216
0 96 ioctl:entry mibiisa -r -p 25216
0 97 ioctl:return mibiisa -r -p 25216
0 16 close:entry mibiisa -r -p 25216
0 124 lwp_park:entry mibiisa -r -p 25216
1 68 access:entry mdb -kw
1 69 access:return mdb -kw
1 202 xstat:entry mdb -kw
1 203 xstat:return mdb -kw
1 14 open:entry mdb -kw
1 15 open:return mdb -kw
1 206 fxstat:entry mdb -kw
1 207 fxstat:return mdb -kw
1 186 mmap:entry mdb -kw
1 13 write:return mdb -kw
1 10 read:entry mdb -kw
1 11 read:return mdb -kw
1 12 write:entry mdb -kw
1 96 ioctl:entry mdb -kw
1 97 ioctl:return mdb -kw
1 364 pread64:entry mdb -kw
1 365 pread64:return mdb -kw
1 366 pwrite64:entry mdb -kw
1 367 pwrite64:return mdb -kw
1 38 brk:entry mdb -kw
1 39 brk:return mdb -kw
Note that CPU 1's youngest records include a series of write(2) system calls by an mdb -kw process. This result is likely related to the reason for the system failure because a user can modify running kernel data or text with mdb(1) when run with the -k and -w options. In this case, the DTrace data provides at least an interesting avenue of investigation, if not the root cause of the failure.
